Thinking of buying and English diff off a local guy says it's out of a 105e
Will it fit straight into my mk2 just to try it
How many teeth does a 4.1 have on Crown wheel and the pinion just so I can check it
Printable View
8 and 33 for a 4.1 m8. will fit but the anglia had a smaller diff flange, so you might have to change that
Brilliant cheers
Same question but how many teeth for a 4.4
The easiest way is to count the teeth and then divide the smaller number into the larger one and you'll have your ratio. From memory Anglia vans were fitted with a 4.44 ratio as were some 1200 Supers.
That’s why I want to know the number of teeth
You'll have to count them. It's 35 yrs since I have seen a 4.4 English diff and my memory has faded so it would be a guess at 9/40.
That’s great thanks chaps
