Duratec dry sump question...
Hello everybody!
I have a Ford Focus race car with an 2.0 Duratec in it, 250 hp spec.
This weekend i siezed a big end bearing for the second time :( , probably because a lack of oil pressure (running a baffeled wet sump) .
I have read som good stuff about Racelines dry sump but i mailed them and they said it's not made for tranverse applications..
The Cosworth dry sump that burton sells should be good for both inline and transverse engines , quite expensive though..
I have found an used dry sump on ebay that's marked caterham at the bottom, does anyone know the difference between the cosworth dry sump and the caterham one???
Do you think i can use the Caterham one? Or should i buy a Pace dry sump kit?
Thankful for some guidance
Re: Duratec dry sump question...
Try talking to AT power.
http://beta.atpowerthrottles.com/pro...9e6ec02b209ed0
Superior pump design to others mentioned above.
The cosworth one don't work as well as they should mate
I have heard sometime about a atpower kit recently which does not install any
Confidence
Pace kit work
My kits work ( opi there on the burtonpower site )
And then there is titans but I probably wouldn't lol
My kit work with the engine either way round
Quote:
Originally Posted by
Lacey The cosworth one don't work as well as they should mate
Confidence
Pace kit work
Pace don't work in my experience!!, only heard good things about the AT power stuff and they certainly knew what they were talking about when I spoke to them.
Proof is running one I guess which i will soon be doing.
It's very rare that pace stuff don't work , but this could be due to the engine build
Atpower where do I start lol
In a word don't be leave all you are told , and when people think they know it all when
They don't , that's when it all goes wrong
There dry sump kits are only a copy/spin off of paces
Then they got the hump with titans about there throttle body's
Very rich lol
The most resent I heard of was someone
Removed a pace kit and brought a atpower kit
Only to be very disappointed in it
And then went on to re for the pace kit as if was far better
And the funny thing about the system about is the way atpower tell the man to put the oil back into the block .
As the bloke that told him done it this way years ago while he was at pace and wiped out his own engine
So he either has a very short memory or is just a little dim
Raceline and Pace works, as does Titan for Duratec (used them all with no problems).
Cosworth caused all kinds of problems in Caterham race cars, solved by using Raceline (with Caterham logo)
If Raceline say it is not for transverse use, then fair enough. I would probably go for tried and trusted Pace set up then
I think the race line one also uses the pace pump
My kits have been use by a fair few people
With Sbd among them with a n/a 2.0ltr duratec making 307hp in there f3 car
With the engine totally sealed and reving to 9600
Wow, lot's of input! Thanks :) ....
Here's the sump i found on ebay ,
http://www.ebay.co.uk/itm/CATERHAM-C...item3ce3383e0a
Thought i could grab a bargain here but after hearing from all of you that i shouldn't i'll guess i will go for the Pace or AT kit...
It's not so cheap building new engines all the time either :)
Kindest Regards
Fredrik
Go pace / customer service is poo but the stuff works
Don't go AT as it will cost you in the long run trust me .
Lacey Go pace / customer service is poo but the stuff works
what is exactly wrong with the at power kit?
I won't go into it on here
But if I get time over the weekend I will be happy to pm you ?
please do as I have one going on soon, cheers :thumb:
4 Attachment(s)
Lacey I think the race line one also uses the pace pump
OK, so you haven't seen the Raceline one then, it uses a specifically designed internal pump, that replaces the OEM one, so no external belts or pump required.
Arguably the neatest install and also the most cost effective and like yours in use in several cars putting out 300+ bhp.
How about some pictures and details of your sump, always interesting to see what options are out there
Attachment 70383
Attachment 70385
Attachment 70382
Does the raceline one work in an escort?
What modifications have to be done?
1 Attachment(s)
doughman Does the raceline one work in an escort?
No modifications to sump, but engine needs to be raised about 10mm on standard WCXM mounts
That's why I said I think as it's along time ago that I was at pace
And now seeing that I remember its R E D that use or used the pace pumps
I assume the unit in the pic works ok
As I know that the titans and cosworth ones don't due to the scavenge
Return being far to small and on a long flat chat they suck the tank dry
Pics of my kits are on the burtonpower website
And my f3 Reynard kit pics are on Sbd,s website
hi lacey do the pace kits need the engine to breath or can the rocker and block breathers be blocked off
Hello mate
You should be able to block it all off
When I was at pace we had customers that did with
No problems
But a one way valve can be used if you wanted
This will let the engine breathe in and not out
On a turbo car you would reverse it to allow for blow by
I am waiting on some to come in if you want one mate ?
Lacey I assume the unit in the pic works ok
The Cosworth ones were a bit of a mare for racing Caterham's, that's why they no longer use them
The Raceline one has had no problems at all and has the option of fitting an extra scavenge pump for "only extreme performance levels will require the need of additional scavenge" It has proven to be fine without the external pump on plain old vanilla sub 300bhp engines.
You kit looks really nice and to be honest will be a bit easier to fit over a cross member of an Escort, personally I like the neatness of the internal pump, not to mention a 400 quid cheaper price. But horses for courses!
I do agree the raceline one is compact , but if you were to add a extra scav stage is that also internal ? Coz if it's external then it will surely defeat the idea of the neatness of it all
And if it needs a extra scav stage for extreme engines then I very much doubt the normal kit will pull
Negative crank case pressure
Thank you I try to do my best lol
It clears a wcxm as I have one I used to dummy it
All up while I was designing it all
I personal proffer a external pump but that's is each to there own
£400 difference in price depends on where you get it from :-)
Not many people run over 300bhp, which does not defeat the neatness. Pete McEwen who designed it, refined and tested it at Mountune and by a mate of his who did some kind of computational fluid analysis test on it, using the same software he uses for F1 engines.
Regardless of your doubts, the Raceline DS is a well proven design with dozens in action on racetracks every weekend in Caterhams etc. I have used it on three engines myself with no issues.
I'd still like to know what's wrong with the at power kit :)
2 Attachment(s)
I can now do a full DS kit which works in either direction.
Contact me on jrprmc1@bigpond.com for full details and pics.
Attachment 71122Attachment 71123
I have extensive experience of the cosworth kit in a 300 bhp escort, works well and had no problems on circuit or rallying, only prob is the engine sits too high in an escort. Can space the x member down but mucks up the geom. I've converted to pace external system but not tested it yet. Dunno how well it works transverse.
Dr Dub I have extensive experience of the cosworth kit in a 300 bhp escort, works well and had no problems on circuit or rallying, only prob is the engine sits too high in an escort. Can space the x member down but mucks up the geom. I've converted to pace external system but not tested it yet. Dunno how well it works transverse.
My DS system is designed to fit the Escort in the original crank CL position (not raised) on the original standard X member and OE Pinto engine mount rubbers (on my cast Al. engine mount-to-block) as shown. No changes to X member or steering required. Scavenge pump has huge capacity for any crank-case vacuum you want to run and the tank remains full under all conditions!
I'm running it in mine at around the 300HP mark and have never even marked a bearing in 3 seasons; I have only changed oil about 4 times in that period whether it needed it or not (LOL) ; proof that it works well.
Cheers,
Roger.
dobuy Not many people run over 300bhp, which does not defeat the neatness. Pete McEwen who designed it, refined and tested it at Mountune and by a mate of his who did some kind of computational fluid analysis test on it, using the same software he uses for F1 engines.
I've referred to your build several times since starting my latest project. You've done some VERY nice work on your car.
I know I'm reviving an old thread here, but I just received a Raceline Dry Sump kit, and I noticed that the pump has a lot of backlash compared to other gear type oil pumps I've examined.
Here's a video I made that shows the backlash.
https://www.youtube.com/watch?v=Ydnk...ature=youtu.be
It also has about .002" end play on each shaft.
Did your pumps exhibit this much backlash?
How much oil pressure did your systems produce?
This is a road race engine, around 300hp, that I'll be spinning to around 9,000 rpm, so I want to be sure I have plenty of oil flow and pressure to handle that kind of rpm.
I also have ARP main studs, and it looks like shortening some studs a bit, as well as clearancing the scraper plates will gain the needed clearance.
Thanks,
David
From your vid
Your back lash is minimal
I have rebuilt a lot of weaver /stock car parts
And of American manufacturered
Pumps with far more movement than that from the factory
Use a good oil from around 15/40 to 20/50 for better results
And on a duratec you need to restrict oil flow to the head as they pump to much
Up there and they retain it there
Lacey From your vid
Thanks, that makes me feel much better.
On another topic, I called Crane Cams yesterday to ask for cam recommendations, and it seems they have discontinued supporting the Duratec.
I wonder if you could recommend cams and valvetrain for my build.
This is for a roadrace car, running a T5 trans and a WInters quick change rearend.
Race weight will be around 1900-2000 pounds with driver.
The block is a Ranger 2.3, with a modified Forged Ecoboost crank, Molnar forged rods, and Wiseco 12.5:1 forged pistons.
The head is a 2.5 unit, casting # RF8E5E from a 2010 Fusion, and I have modified the oiling system to feed the front intake cam journal from the main oil feed instead of through the VVT system.
The head will be fully ported, with 1mm oversize intake and exhaust valves.
Intakes will be 50mm ITB's, and due to space limitations in the chassis, we're designing a billet intake that will place the throttles as close to the port as possible, and angled up approximately 45 degrees or so.
I plan to fabricate an airbox over the airhorns, and duct cool air from a remote filter behind the grille
I'm aiming for peak power to be around 8,000 - 8,500 rpm, and would like to see over 300HP if possible.
I see cams from Kent Cams, and Cat Cams, but don't know much about either company.
I do like the Kent Cams design, which comes with an adjustable sprocket standard, and gets rid of the single bolt/friction washer setup, but I need to make sure they offer them in 38 tooth to match my oil pump and crank gears, and chains.
Your thoughts would be appreciated.
Thanks,
David
PS: I'll also start a new thread with this question, in case anyone else has input.
Burtonpower stock Kent cams
They maybe able help and they will ship
