Anyone know which Ashley 4 branch manifold is closest to a pinto block Escort or Capri ? Or is there any other manifolds I can look for ?
Printable View
escort and capri manifolds are slightly different, but they will both run the same distance from the block,
what are you trying to do?
I'm putting a pinto in a Ford Thames but the exhaust is going to be tight, I remember someone years ago said there was a manifold that was tight to the block
I have a Pinto 4 into 1 ex manifold somewhere, if I can find it I'll take some measurements. From what I can remember it did n't look as though it would run too close to the inner wing and chassis. I bought it to go on a Pinto Rally engine but decided on the Group 2 Ashley 4-2-1 one after a lot of consultation.
RS manifold.
ok, but that does beg the question, why on earth? ford thames isnt exactly a racing machine!
i just dont get why so many people want to use a full race cam in a road car
There is only a very small chance you can make this cam work, even in a race engine. You need a very serious head or it will be a full "negative" power engine.
About manifold, only the big bore Ashley will release the full power of this cam/engine combination (in case you really got the right head). You can skip all other options.
The engine was built for oval circuit hot rod racing
OK, if on twin Webers, that's where these cam's can be used for. And your intention is oval or hot rod racing?
The 4 into 1 four branch manifold for a Pinto that I have measures approx 190 mm from the cylinder head flange to the out pipes if that makes any sense.
