Workshop manual for 2.0L Blacktop mk3 Zetec
I am using a 2.0L Blacktop mk3 Zetec for building a Lotus Super7.
I need to buy fuel line (up and down). which diameter do I need?
I need a fuel pump (which pressure, what capacity)?
I want to know which sensor has which function?
Is there a build in fuel pressure regulator?
In other words, where can I find/buy a garage workshop manual that answers all those questions.
Thanks in advance for your advice.
Cees
Re: Workshop manual for 2.0L Blacktop mk3 Zetec
Assuming a 135hp output and using the standard injection i'd say 6mm ID bore flow and returns - if swopping the injection for ITB's - Jenveys for example then I've upped the flow to 8mm ID on my RS2000 install which should output about 175hp.
Fuel pump - https://www.fuelpumpsonline.co.uk/sy...017-1931-p.asp - would be fine for this install.
What sensors are required will all be subject to what the ECU requires / needs to work correctly.
A Haynes manual for a 2000 / 2001 will detail most of what you'll need for a Blacktop Zetec
Hi Katana,
thanks for your clear answer. I will get the Haynes manual.
I have a new create engine with fuel rail and sensors already installed. Only no ECU. I assume it will be more cost effective to look for an ECU that matches the current engine. Is that a correct assumption?
Cees
The only ecu that will exactly match the engine without modification or tuning will be the OEM Ford item......not necessarily the best choice as it will require more items from the original car that you will likely not be fitting as it monitors a lot of associated electrical systems and may default to 'fail safe' if it can't find them or it thinks they have failed! And they aren't necessarily tunable for alternative intakes / exhausts etc.
Most aftermarket ecu's can be reprogrammed / tuned to work with any engine and / or the suppliers will have baseline programs / maps to work with a Zetec B/top and generally will work with bare minimum associated electrical requirements.
Pffft, I understand what you are saying. This is exactly why I do not want to buy a Ford ECU.
I was hoping to buy an after market ECU, hook it on to the different sensors and dial it in.
but first, I need a proper manual...
I contacted haynes to buy a manual but they can not help me beause they do not know which of their manuals is suitable for my 2.0i blacktop mk3 Zetec DOHC.
Any idea which manual this can be?
if you want an aftermarket ecu why do you need a haynes manual?
it will either tell you nothing, or loads of stuff which isn't relevant to your installation
Thanks for your question Graham.
I have exerience with fitting and tuning a throttle body system on an V8 from Fordracing. I have no experience with Zetecs.
Katana kindly gave me the answer to my questions about fuel line and fule pump but I have so many more.
There are several sensors on the engine which I want to identify. There some parts on the engine where I do not understand the function. Is there a fuel pressure regulator included in my engine? Etc.
most zetecs are dead headed on the fuel rail, ie no regulator at the rail and no return, the regulator is attached to the pump in the tank, all you need do is look at the fuel rail to see.
it would be a lot simpler if you could just post a picture or two of your engine, we could then name bits for you rather than guessing. as far as sensors go, in the main aftermarket ecus only really need, crank sensor, coolant temp and throttle position, if you have a cam senor ( which your engine will have) as well you can have sequential injection too. ideally but not overly important, you want air temp sensor, but the zetec has that incorporated in the air mass meter, which you dont use with aftermarket ecus
Graham,
I hate to ask so simple newbe questions but, I agree, this is the best way now.
I can not upload pics. Here they are: (link is valid until end of this year.)
https://cees123.stackstorage.com/s/jhB3rrN4Wad4hL9
Photo 1 What is supposed to be here?
Photo 2 Is this the crank shaft speed sensor?
Photo 3 Is this the crankcase ventilation system oil separator?
Photo 4a+b Is this low oil pressure sensor?
Photo 5 No Idea
Photo 6 Throttle position sensor?
Photo 7 no idea
Photo 8 Water temperature sensor?
Photo 9 fuel feed, return and pressure regulator according to arrows in picture.
More general pics are in:
https://cees123.stackstorage.com/s/WIwtKypzT6M4P2k
Thanks in advance for your answers.
Cees
1 probably an air con compressor, but could be many things, nothing though important to the running of the engine
2 yes
3 yes
4 yes
5 cam sensor
6 yes
7 vacuum pipe for something, not important to you
8 cylinder head temp, this is NOT coolant temp, that is in the thermostat housing.
9 yes
Hi Graham,
That is great. With such advise and expertise, who needs a manual?!!
Thanks.
I checked the thermostat housing. and added picture 10a, b and c
There is nothing in sight that looks like a sensor.
On picture 10a, there is a spot, see marked arrow. Is this the place where a water temperature sensor should be?
Cees
BTW, next week Saturday, I will go to a motor mngt instruction class. http://www.bs-autotune.nl/content/view/108/121/
Quote:
Originally Posted by
Ceesdoets
Seems like a good course for newbies but they probably want to promote and sell their own stuff too.
Ceesdoets Hi Graham,
Thanks.
Cees
yes , its held in with a metal clip
Miniliteman Seems like a good course for newbies but they probably want to promote and sell their own stuff too.
Yes + yes.
