Results 1 to 12 of 12
Thread: Braided brake hoses
    Mechanic beeRS's Avatar
    Apr 2007
    Chelmsford
    773
    114
    Braided brake hoses
    I'm planning on making up some dash 3 stainless steel braided brake hoses. I've never done this before. Does anyone have any advice for someone new to this? What materials to use, what tools will I need, and where to buy from?
    Any help would be appreciated.
    Pit Crew Decade Plus User MegatronUK's Avatar
    Jun 2006
    Durham, UK
    1,494
    Re: Braided brake hoses
    I got all my stuff from Torques on Ebay. You'll need the PTFE lined hoses and the stainless ends with olives. All you need to do is mark the length, put some tape around the hoses where you intend to cut them (and use a very sharp hacksaw blade - you don't want any fraying), take the tape off carefully, then push them into the ends and tighten.
    Really simple compared to the bigger bore fuel and oil hoses! Just be careful that the olive should be replaced if you need to adjust the length and require to re-cut them.
    Hose ends:
    http://stores.ebay.co.uk/Torques-U-K...4.l1581&_pgn=2
    Hose:
    http://stores.ebay.co.uk/Torques-U-K...=p4634.c0.m322
  3. The Following User Says Thank You to MegatronUK For This Useful Post:
    Jan 2016
    Hull
    246
    I use a slit disc on angle grinder for cutting after as said couple of wraps of tape helps to reduce the fraying.
  5. #4
    Apr 2007
    Chelmsford
    773
    114
    Thanks for that useful info. The stuff from Torques appears to be good quality.
    Are you supposed to use any thread lock or PTFE tape on the threads when making up the ends, or just build them dry?
  6. #5
    Jan 2016
    Hull
    246
    Just build dry.
  7. #6
    Jun 2006
    Durham, UK
    1,494
    Yep, no thread tape on brake pipe ends. What you do is cut as above, open up the braiding slightly, insert the olive so that it sits between the inner ptfe tubing and the braiding, then tighten, the hose end then clamps down around the olive and makes the seal. It's a neat system that works really well.
    If I were you I would go to a company like "Hell" that'll make you your pipes up with proper crimped ends on to your required lenghts. I don't like the olive type that compress onto the ptfe pipe, the wire always seems to be in the way. Often when the nuts tightened it baulks on the wire and twists the pipe.
  9. #8
    3,248
    I've never had that problem - you flare the braid out before pushing the olive on....make sure its well seated, hold fitting in vise and screw nut down. If alignment is critical use a swivel fitting!
  10. #9
    I can assure you I have done it the correct way Katana, I think they are a poor method of fittings for a brake pipe. A crimped fitting will always be the better option. Tiny little olives on ptfe pipe are better left for air line fittings in my opinion.
  11. #10
    Racer Decade Plus User robrs2's Avatar
    Jun 2003
    Teesside
    2,406
    Got my lines from Rally Design, same stuff. Its best to cut the line with a thin disc cutter as said above. Remember to blow lines clear. I've never had any problems putting the fittings together. They are a very tough connection, never had one leak or come apart.
  12. #11
    Apr 2007
    Chelmsford
    773
    114
    I'm resurrecting this old thread of mine to ask another related question.
    Two year later on, and I'm still working on these brake lines. I'm using dash 3 lines from the master cylinders to the calipers, but I've been told I should use larger dash 4 lines from the remote fluid reservoirs to the master cylinders. Is it common practice to use a large line to remote reservoirs? Should I do the same with the clutch reservoir?
  13. #12
    Pole Position Decade Plus User meXEco's Avatar
    Mar 2003
    TRURO
    5,253
    247
    Yes dash4 feeds to cylinders and dash3 from cylinders.
