Wheel fitment in wheel arch. Looks good so far.
Please NOT. These are not the wheels it will run on. They only for measuring
Very nice work Scooby.
330mm discs and 8 pot calipers. Think she would stop with these on. And they fit inside 17inch rims
Rear axle mounts nearly finished. And some nice sill stands to boot
Rear beam
Delivery today. Can use guess
From this to THIS. Fully rebuilt.
Sent from my SM-T560 using Tapatalk
Running thru this. Mazda rx8 6 speed
Zx9r carbs on full rebuilt st170
Solid rear mount for diff. And front compression struts
Trial fitting of rear antiroll bar
Starting to take shape now. Antiroll bar mounts made up just needs welding
Solid rear mount
Axle fitted at last. Next big job get the shocks to fit
some great work going on there
Rear Gaz coilovers trial fitted. Looks ok but want to move location slightly. So next job
wow likeing this
Coilovers
New diff breather made up
Breather
Solid mount bolted up
Made up new shock location. All fitted up
Strengthend shock mounting
Rear axle all fitted. Now onto making new boot for to suit. Then transmission tunnel..
This project is gona look the bollocks .
Vented front wings
Tippy Tappy ???????
Suppose to have read. Boot floor
Hi katana.
Do u mean I'm posting pics and stuff that I can see on my posts. But the rest of you cant see them.
Please help as I'm a bit of a dummy where computers are concerned. Thanks
Mike
I can't see them either, so Katana is right. Seen some of them and really like youre work and ideas.
Mr mk2.
How can I make them vizable to all who reads the posts then. Thanks for comment. I'm in no rush to build it. Just wana build it Right.
Cheers mike
im always using a laptop but not seeing them ? i just see
"Sent from my SM-N9005 using Tapatalk"
alladdin.
Im always using a laptop but not seeing them ? i just see
"Sent from my SM-N9005 using Tapatalk"[/QUOTE]Hi all adding.
What am I doing wrong if nobody can see my pics. Cause if I go on . I can see what I post. ???????
Cheers mike
hello scoo by mike.
i dont think its you i think its a forum error - other threads are the same for me.
