would a mk2 van wing fit my mk1 escort 2 door? i know there is a diference on section of it that you weld to the a post,but would it fit??
cheers,auldy
cheers,auldy
Do you mean mk1 van wing? mk2's are completely the wrong shape! If its mk1 to mk1 then yes, just the pillar section like you mention that might be different
i thought mk1 and mk2 van wings were the same??
cheers,auldy
How can they be a mk1 is totally different around the headlight and the bodyline is different too. Also the mk2 bonnet is wider than a mk1 so the wing rails and wing tops are completely different
it's the whole front end that can be swapped on vans &/or estates isn't it??
Yep
The doors are the same though, aren't they?
Scouse.
Externally only though isnt it as each model runs the insides (winders and cards) of the saloons?
imhave been wrong,soz!
cheers,auldy
Isnt a Mk2 van just a Mk1 van with different front panels??
therefore could the Mk2 Van wings fit a Mk1 saloon
In theory they should do, i wonder what it would look like though
