Anyone that has fitted a duratec using the ranger sump able to give some advice, was it just a simple bolton replacement for the standard Sump or did it need additional modifications? Info I have found so far says both
Tia ed
Tia ed
you also need the ranger pickup pipe which may need bending slightly depending on which oil pump you use, it was a right pain getting mine to fit in the engine bay and i ended up significantly modifying the cross member to get it all to fit
i modified a ranger sump with a big wing plus raised the pickup pipe a and tig welded in a plate to raise it to give crossmember clearance for escort fitment
seemed to work ok
photos here
http://www.turbosport.co.uk/showthre...=160260&page=3
