Results 1 to 16 of 16
Thread: Ford Taunus 5 stud to 4 stud conversion. Can it be done?
    Feb 2015
    Portugal
    Ford taunus 5x112 to 4x108?
    Can it be done?
    Have someone done?
    How costly and how difficult?
    Best Regards
    3,248
    Re: Ford Taunus 5 stud to 4 stud conversion. Can it be done?
    Anything can be done subject to time, inventiveness and money. Wouldn't it be easier to just replace the whole / both half shafts?
    Feb 2015
    Portugal
    Replacing the halfshafts is costly.
    Taunus 17M is basically a 50" Atlas with 5 stud.
    If I can convert it would be plug n play
    3,248
    In that case then subject to who does the work is the cost aspect. The method would be knock the studs out, plug weld up all of the holes and dress back flat. Mount in a chuck on a rotary table and mount on cross slide of a lathe. Centre the half shaft on lathe spindle, adjust cross slide for 100PCD, drill 1st stud hole (sized for press fit) with drill in lathe chuck. rotate rotary table 90 degrees, repeat drilling x3, de-mount and press in the 4 studs - repeat for other shaft. Finding a machine shop willing to do it is another thing. Of course the setting out of the holes can be done other ways and the holes could be done 'free hand' - how good are your engineering skills?
    Sep 2004
    Ireland
    354
    18
    i do this type of work on a regular basis i run my own machine shop if you cannot find someone local to do it for you send me a pm
    May 2004
    Norn Iron
    1,145
    5 studs surely better ?
    Veicomer ?
    9.85 @ 145mph 202mph standing mile
    https://www.youtube.com/watch?v=Ss_c7fML3rw
    Mechanic beeRS's Avatar
    Apr 2007
    Chelmsford
    773
    114
    I had a job like this done for me by Chris Isaac Race Cars, but thats in Essex.
    A lot of modern production cars have gone back to five studs. Unless you have a stack of 4 stud wheels you are wanting to use I would stick with 5 studs unless your choice of wheels is limiting you.
    You can buy hubcentric wheel spacers to covert to any PCD / stud pattern you like.
    Feb 2015
    Portugal
    But in this case it will push the wheel out at leats 20mm on each side.
    Feb 2015
    Portugal
    Quote Originally Posted by beeRS View Post
    On a taunus axle?
    from 5x112 to 4x108?
    If so whats the process tehy used?
    Feb 2015
    Portugal
    Already have the wheels.
    Compomotive ML 4x108 8x15 ET-12
    Feb 2015
    Portugal
    Quote Originally Posted by stevieturbo View Post
    Veicomer ?
    They are very near me...
    I haven't ask Ricardo yet.
    My only concern with them is the price... loooool
    Feb 2015
    Portugal
    Quote Originally Posted by mick32 View Post
    Will do Mick
    Feb 2015
    Portugal
    Doing it "free hand" the probability of something going wrong is like 99%. loooool
    Apr 2007
    Chelmsford
    773
    114
    Quote Originally Posted by Salti View Post
    On a taunus axle?
    It was on a Volvo axle, but the principle would be very similar. Chris, changed my half shafts from 5x108 to 4x108. This meant he could keep one hole where it was and drilled 3 more holes and fitted studs to the other 3. There was no need to weld up the 4 old holes in this particular case.
