T-adaptors - Who sells them?
I need a T-adaptor to fit an oil pressure and oil temperature sensor instead of the old warning light switch.
Can anyone recommend somewhere that has these parts?
I need 1/8 NPTF for the block (thread outside), and 1/8 NPTF inside thread for the temp. sensor and 1/8 BSP inside thread for the pressure sensor. This is an SPA dual meter, being fitted to a CVH.
Maybe one of you can make this up? Otherwise I'd be grateful for some good links or telephone numbers.
Thanks!
Re: T-adaptors - Who sells them?
C'mon someone must have a good contact for these things, even if it's just a hydraulics firm or similar. Can't any of you make this up for me - if so just name the price.
Try Think automotive www.thinkauto.com
0208 568 1172
if these guys can't help then I dont know who can
Steve
Just pop down to your local plumping/hydraulics place. look in your yellow page bound to be aplace local
The Think site is great - but they want well over 20quid for them.
Is that normal? I was expecting them to cost a quarter of that!
Toppy if you know someone in Oxford let me know as I have good connections there.
Thanks for the tips though!
I use pirtek on hospath ind est for most of the stuff i need dont think its the cheapest but its only 5 mins away from me
something like this maybe
I think that pic needs some explanation - how many adaptors have you got, and what is happening with the filter?
Final question - how much do these adaptors cost?
the one screwed in to the block is off a escort cosworth which has to outlets i used the bottom for the switch top one i put the adaptor for the turbo oil feed and were the switch used to be i put oil pressure take off
And the filter is just a convenient thing to wrap the hose round?
Do you have a thread on your build - the details would be interesting...
