boost problems
Hi all hopefully someone will be able to help
Ive fitted a yb engine to my mk3 cortina it has stage 3
Ive tried it down the road today but just doesn't seem to boost ive got a -31 actuator ive set it up and then been trying 1/2 turn shorter and it seems to be that wherever its adjustment i only get 0.8 bar of boost full throttle down the road
Re: boost problems
Pull the pipe off the bottom of the turbo, off the brass one screwed into the turbo , then take it up the road and watch the gauge , this will give unlimited boost so be carefull, just watch the boost rise , if it don't make boost you have a problem , could be Amal valve , air leak , map sensor ?
Re: boost problems
Cheers mate
I will give it a go i did remove the amal valve but was no different
Re: boost problems
Does anyone know what boost pressure i should be getting from a stage 3
Re: boost problems
Depend who's chip or map , if it's msd they love 2bar !!, but I'd say between 18 /25 max then it will tail off , unless joe at gs Motosport has mapped it then it just holds all the way to the limiter !!
Re: boost problems
If it was me would get the car set up properly ,as would like to know fueling and compression test just to check health of engine
Re: boost problems
Ok cheers
I know its a l8 ecu with superchips
Dark green and 3 bar etc
