Firstly I am testing the water with this, chances are all this will be for sale but until I know for sure the replacement car is available I won't be selling anything.
Honda S2000 engine, low miles
NEW TWM 52mm Throttle Bodies with injectors and regulator
NEW RED dry sump setup
6 speed gearbox
£5000
NEW TTV 7 1/4 billet flywheel £220
Ohlins 2 way coilovers, a few events old, need to check spring rates with J-tech but I will sort that.
come with alloy top mounts
£2000
Brand new Gripper Atlas LSD £750
NEW Cobra Monaco seats, 1 set of Cobra sidemounts £250
NEW Pace 7 litre dry sump tank, splits in the middle, new but a few marks £200
New Aeroquip, -10, -12, -6 hose with fittings, ASK
NEW Pace remote filter housing £40
NEW Bosch 044 fuel pump with -6 fittings £120
Facet fuel pump £40
Perspex door windows with sliders, supplied by P4P £120
NEW 2 x Kumho V70A 225/50/15 hard compound semi slicks £200
Carbon spare wheel tray, from Paul Alexanders car £60
Quick Rack with track rod ends £120
NEW Alloy radiator £150
Upright hydraulic handbrake £50
On top of all that I also have some other parts that are currently with the shell I had built.
1979 Grp4 RS2000 Acid dipped
Fully restored, new floors, roof, RS inner wings,
Flat front
Twin bulkhead skin
Custom engine strut brace
Chassis mounts to suit Yb or Pinto
Tarmac arched
6 linked
Exhaust tunnel
14 point SD cage, welded in and extended through bulkhead
Fully painted inside and out in original RS gloss black
Shell finished by Odell Motorsport
OFFERS
Gartrac narrowed Atlas axle casing, diamond brackets and coilover brackets
NEW Gaz Coilovers, a few years old but were only fitted for a few months, come with alloy top mounts.
Watts linkage back plate and arms, may go with shell
4 x RS2000 alloys
Another Quick rack
Oil coolers x 2
