Results 1 to 18 of 18
Thread: Pinto manifold
    Bodger nbs's Avatar
    Aug 2009
    Bristol
    64
    Pinto manifold
    Anyone know which Ashley 4 branch manifold is closest to a pinto block Escort or Capri ? Or is there any other manifolds I can look for ?
    Re: Pinto manifold
    escort and capri manifolds are slightly different, but they will both run the same distance from the block,
    what are you trying to do?
    Bodger nbs's Avatar
    Aug 2009
    Bristol
    64
    Re: Pinto manifold
    I'm putting a pinto in a Ford Thames but the exhaust is going to be tight, I remember someone years ago said there was a manifold that was tight to the block
    4,889
    Re: Pinto manifold
    Re: Pinto manifold
    I have a Pinto 4 into 1 ex manifold somewhere, if I can find it I'll take some measurements. From what I can remember it did n't look as though it would run too close to the inner wing and chassis. I bought it to go on a Pinto Rally engine but decided on the Group 2 Ashley 4-2-1 one after a lot of consultation.
    4,889
    Re: Pinto manifold
    RS manifold.
    Bodger nbs's Avatar
    Aug 2009
    Bristol
    64
    Re: Pinto manifold
    Thatll be great Cheers
    Bodger nbs's Avatar
    Aug 2009
    Bristol
    64
    Re: Pinto manifold
    Really need a 4 branch its a built engine
    Quote Originally Posted by Miniliteman View Post
    RS manifold.
    Re: Pinto manifold
    Quote Originally Posted by nbs View Post
    actually unless you have a mad cam the rs manifold is quite good, even a standard sierra twin downpipe jobbie is quite good.
    Bodger nbs's Avatar
    Aug 2009
    Bristol
    64
    Re: Pinto manifold
    Got a Kent HT1 cam
    Re: Pinto manifold
    ok, but that does beg the question, why on earth? ford thames isnt exactly a racing machine!
    Bodger nbs's Avatar
    Aug 2009
    Bristol
    64
    Re: Pinto manifold
    And why not ? Its different than a MK1 MK2 Escort. Ive just sold my ST170 engined 100e as I wanted something different
    Re: Pinto manifold
    i just dont get why so many people want to use a full race cam in a road car
    Mar 2012
    2,118
    Re: Pinto manifold
    Got a Kent HT1 cam
    There is only a very small chance you can make this cam work, even in a race engine. You need a very serious head or it will be a full "negative" power engine.
    About manifold, only the big bore Ashley will release the full power of this cam/engine combination (in case you really got the right head). You can skip all other options.
    Bodger nbs's Avatar
    Aug 2009
    Bristol
    64
    Re: Pinto manifold
    The engine was built for oval circuit hot rod racing
    Mar 2012
    2,118
    Re: Pinto manifold
    OK, if on twin Webers, that's where these cam's can be used for. And your intention is oval or hot rod racing?
    Re: Pinto manifold
    The 4 into 1 four branch manifold for a Pinto that I have measures approx 190 mm from the cylinder head flange to the out pipes if that makes any sense.
    Bodger nbs's Avatar
    Aug 2009
    Bristol
    64
    Re: Pinto manifold
    Thanks mate ill have a measure tomorrow
