Should the layshaft on a type 9 gearbox have movement in it if so what would be classed as acceptable ?
Do you mean.the input shaft ? That will wobble a+/- a mm or 2
Hi alladdin that was quick kid
ye shaft the clutch would be on
I would sa I ha between five to eight mm of movement
So would this mean the input shaft bearing is naffed then
Yeap - mine had less than that - 'bout 3mm - but gearbox man changed the bearing whilst it was apart - pennies to do and it doesn't wear tighter! LOL
anyone no a site that gives you a guide on stripping the box down to do such repairs as this bearing and so on
Yes, it's on here lol.
You could always just try it, it's got a spigot bearing supporting it once fitted.
But yes, it won't get better
Good point
First post in the running gear section, a sticky.
