Z20let mk2 escort
Thinking about putting a z20let in my mk2, has anyone done this before or know any issues I may have? Any help would be great, cheers, Elliot
Re: Z20let mk2 escort
Hi Mate
Im in the process of doing it
my thread is somehere on here in the resto section
try here
http://www.turbosport.co.uk/showthre...603&highlight=
That's a luvly resto you got going there! Wish I had the same sort of budget lol, I see your using a c20let there, do u know if there is any issues I may have using a z20let?
You wont really have any different issues than me lol
are you using original turbo or going down the nissan 200 route.
also are you cutting the heater bowl out to fit engine further back
pm me if you want my mobile number then you can have a chat about it
Z20let mk2 escort
One hassle with z20let is its fly by wire...
And I'm sure it runs as part of the canbus systems the ecu etc.
I was planning on using the original turbo what's the advantages with the Nissan turbo? Dont realy want to cut the heater bowl out unless i realy have to, does anythibg need modifying to the back if the engine on the z20lets to get it to flush, like the redtops need the dizzy removing and blaning off? And as for the wiring I was thinking running it with a megasquirt ecu
im fitting a z20let to my kit car. only at the parts gathering stage so far though.
ideally you'll want a t5 gearbox as a type 9 might not last too long if you get greedy with torque (might as well build it tough from the start).
bellhousing from rwd motorsport, SBD can supply the clutch set-up.
megasquirt is probably a good idea, ive only ever used megajolt, but had no issues with that so will be using megasquirt when the time comes
you can use the throttle body from a x20xev which is a cable operated TB and fits straight on.
it's possible, but it's not a very cheap engine transplant from what i can see
Z20let mk2 escort
They are insanely easy to megasquirt,
If any one needs any advice or help just ask,
I had a megasquirted turbo'd c20xe!
Hi was wondering if you could help me as you said u have had exsperiance with megasquirt, I have never used it, what coil pack would I need to use, and would I be able to get a base map from somewhere or would I have to start from scratch, is there any additional sensors I would need to run? Any help would be brilliant, cheers, elliot
Z20let mk2 escort
I can email you over a base map, but it literally is just that.
I used a coil pack off a 2.0 ecotec engine, usually found in Astra's vectras etc,
Has your ecu had the extra ignition driver fitted?
Sensor wise you need,
Tps,
Map sensor(built in to ecu)
Tps (optional but I recommend it)
Crank sensor,
Intake air temp,
Coolant temp,
I havnt yet brought an ecu as wanted to clear up everything I need, do I new the extra ignition driver do I? And all the sensors u named are they the standard sensors for the engine?
Z20let mk2 escort
Yes too use wasted spark you need the extra ignition mod,
I used all the standard sensors bar the intake temp, I used the one diyautotune sell, it's a gm one, but you could use any it'll just need setting up,
And obviously the map sensor is built into the ecu,
You'll have to check your tps is a normal tps And not a switch also, but it should be normal.
