Hi, does anyone recognise this alloy bellhousing?
Hi There
This bellhousing was on a Lotus Twincam, but I was going to use it on a Zetec 2.0 with a 1.8 flywheel and type 9 G'box. The zetec flywheel very slightly fouls the bellhousing, and I could grind it slightly, but then I thought I may as well just use it with the original Twincam in a different car.
However, I am curious as to what it would have originally come from. There are no identifying marks.
Please ignore last image, its an alternative iron bellhousing.
Many thanks
Berni
Re: Hi, does anyone recognise this alloy bellhousing?
Originally Posted by
Paul Finn Is it an RS 2000 one
No! RS bell has dual starter holes + the gearbox mount isn't right shape.
if not lotus as above i would google ginetta etc and other oddball ford users.
