Cant get corsa c pas to work
I fitted a corsa c column to my escort, bought the controller off ebay, connected the main 12v and earth, then connected a ignition live and earth to the controller
when i turn ignition on the ecu clicks but the steering is still heavy and the adjuster doesnt seem to do anything, i pulled the complete column out of a corsa c that i had been using so i know it worked fine in there
any ideas?
