Results 1 to 6 of 6
Thread: Magnum Panels - Escort Mk1
    TURBOSPORT SPONSOR Turbosport Sponsor TJM's Avatar
    Jul 2004
    Bridgend, Vale Of Glamorgan
    644
    Hello to all
    Below you will see the current list of Magnum Panels for the Escort Mk1:
    25-16-76-0 MK1 Seat Centre X Member (Formally 25-16-001)
    25-16-00-1 MK1 Sills 2 Door
    25-16-00-2 MK1 Sills 2 Door
    25-16-01-1 MK1 Full Sill 4 Door As original
    25-16-01-2 MK1 Full Sill 4 Door As Original
    25-16-06-1 MK1/2 Car Inner Sill 2/4 Door
    25-16-06-2 MK1/2Car Inner Sill 2/4 Door
    25-16-06-1E MK1/2 Inner Sill No Cut Out Centre Channel ( Restoration Design )
    25-16-06-2E MK1/2 Inner Sill No Cut Out Centre Channel ( Restoration Design )
    25-16-07-1 MK1/2 Outer Sill To Floor
    25-16-07-2 MK1/2 Outer Sill To Floor
    25-16-20-0 Mk1 Front Panel Round Headlamp
    25-17-20-0 MK1 Front Panel Square Headlight
    25-16-20-1 MK1 Frt Pnl R/H With Starter Handle Hole
    25-16-20-2 MK1 Front Panel + Ventilation Holes(Rallye Version)
    25-16-20-3 MK1 Inner Front Panel 1971-75 All Models
    25-16-20-4 MK1 Inner Front Panel Van
    25-16-20-5 MK1 Inner Front Panel 1968-714 All Models
    25-16-20-04 MK1 Inner Front Panel Centre Strut
    25-16-20-05 MK1 Inner Front Panel Centre Strut With Starter Handle Bracket
    25-16-20-06 MK1/2 Slam Panel Bracket ( Bonnet Catch )
    25-16-23-0 MK1 Front Crossmember
    25-16-25-3 MK1 Headlamp Bowl RHD
    25-16-25-4 MK1 Steel Headlamp Bowl LHD
    25-16-27-0 MK1 Bonnet Slam Panel 1973-75
    25-16-27-1 MK1 Bonnet Slam Panel 1969-73
    25-16-27-2 MK1 Bonnet Slam Panel 1968-69
    25-16-29-0 MK1/2 Spare Wheel Trough
    25-16-29-1 MK1/2 Petrol Tank Trough
    25-16-31-1 MK1 Standard Front Wing As Original L/H
    25-16-31-2 MK1 Standard Front Wing As Original R/H
    25-16-31-3 MK1 Mexico Front Wing As Original L/H
    25-16-31-4 MK1 Mexico Front Wing As Original R/H
    25-16-32-0 MK1 Scuttle
    25-16-38-0 Lower Bulkhead ( Firewall)
    25-16-10 MK1 Inner Wing L/H
    25-16-38-2 MK1 Inner Wing R/H
    25-16-38-3 MK1 Inner Wing Mexico Avo Type ( Fully Dressed ) L/H
    25-16-38-4 MK1 Inner Wing Mexico Avo Type ( Fully Dressed ) R/H
    25-16-38-5 Mk1 Radiator Support
    25-16-38-6 Mk1 Radiator Support
    25-16-38-9 MK1/2 Heater Hose Cover ( Bulkhead )
    25-16-39-1 MK1 Splash Shield Front A Panel
    25-16-39-2 MK1 Splash Shield Front A Panel
    25-16-39-5 MK1/2 Splash Shield Stiffener ( Per Pair)
    25-16-40-1 MK1 Door Jamb
    25-16-40-2 MK1 Door Jamb
    25-16-40-3 MK1 Inner Door Jamb L/H
    25-16-40-4 MK1 Inner Door Jamb R/H
    25-16-41-1 MK1 Wing Mounting Band
    25-16-41-2 MK1 Wing Mounting Band
    25-16-41-3 MK1 Rear Of Mounting Band
    25-16-41-4 MK1 Rear Of Mounting Band
    25-16-42-1 MK1 Top Sus. Panel 2/4 Door
    25-16-42-2 MK1 Top Sus. Panel 2/4 Door
    25-16-42-1E MK1 Strut Reinforcement 1.4mm Thick Avo Type
    25-16-42-2E MK1 Strut Reinforcement 1.4mm Thick Avo Type
    25-16-43-8 MK1/2 Heater Box Bulkhead Repair Panel
    25-16-43-9 Mk1 Heater Box 1970-75
    25-16-43-10 MK1/2 Fan Seal + Heater Pipes Seal in 6mm EPDM Sponge
    25-16-45-0 MK1/2 Under Wing Suspension & Side Panels To 1977
    25-16-45-1 MK1/2 Under Wing Suspension Support Pan Only To 1977
    25-16-45-2 MK1/2 Under Wing Kit To 1977
    25-16-45-1E MK1 Side Support Inner Wing ( Pan ) Avo Type N/S
    25-16-45-2E MK1 Side Support Inner Wing ( Pan ) Avo Type O/S
    25-16-45-OE MK1/2 Pan Support Reinforcements AVO/RS Type Per Pair
    25-16-51-1 MK1 Full Rear Quarters L/H
    25-16-51-2 MK1 Full Rear Quarters R/H
    25-16-55-1 MK1 Inner Rear Wheel Arch
    25-16-55-2 MK1 Inner Rear Wheel Arch
    25-16-59-1 MK1 Rear Wheel Arch 2 Door
    25-16-59-2 MK1 Rear Wheel Arch 2 Door
    25-16-65-0 MK1 Complete Back Panel Up To 1968
    25-16-65-1 MK1 Back Panel Complete 1968 Onw With Reversing Light Holes
    25-16-68-0 MK1 Back Panel Outer Skin
    25-16-69-0 MK1/2 Battery Tray ( Boot Type )
    25-16-69-1 MK1 Battery Tray ( Engine Compartment ) With support
    25-16-69-2 MK1 Battery Tray, Mexico, Twin Camm RS1600
    25-16-74-3 MK1/2 Front Floorwell 2/4 Door
    25-16-74-4 MK1/2 Front Floorwell 2/4 Door
    25-16-74-5 MK1/2 Tunnel Cover
    25-16-74-6 MK1/2 Automatic Gear Box Tunnel Cover
    25-16-74-7 MK1/2 Large Gear Box Cover
    25-16-75-0 MK1 Full Floor With Front & Rear Seat Brackets
    25-16-75-1 MK1 Full Floor Skin, No Brackets/Tunnel
    25-16-75-6 MK1/2 Gear Box Mounting Brackets
    25-16-75-7 MK1/2 Gear Box Tunnel Brace
    25-16-76-0 MK1 Seat Centre Cross Member ( Formally 25-16-00-1 )
    25-16-76-1 MK1/2 Rear Floorwell 2/4 Door
    25-16-76-2 MK1/2 Rear Floorwell 2/4 Door
    25-16-76-3 MK1/2 Rear Seat Brace
    25-16-76-5 MK1/2 Sill Closing Panel N/S
    25-16-76-6 MK1/2 Sill Closing Panel O/S
    25-16-76-8 MK1/2 Steel Bung For Floor Pans Small Hole
    25-16-78-0 MK1/2 Jacking Point Support
    25-16-81-1 MK1/2 Centre Chassis Section
    25-16-81-2 MK1/2 Centre Chassis Section
    25-16-81-3 MK1 Front ( Engine ) Chassis L/H
    25-16-81-4 MK1 Front ( Engine ) Chassis R/H
    25-16-81-5 MK1/2 Rear Chassis Section L/H
    25-16-81-6 MK1/2 Rear Chassis Section R/H
    25-16-81-20 MK1 Rear Chassis Sring Hanger
    25-16-81-OE MK1 Rear Skid Panel
    25-16-81-5E MK1/2 Rear ATB Bracket N/S
    25-16-81-6E MK1/2 Rear ATB Bracket O/S
    25-16-88-0 Escort MK1 Boot Floor Complete To 1975
    25-16-90-3 MK1 Front 1/4 Chrome Bumpers N/S
    25-16-90-4 MK1 Front 1/4 Chrome Bumpers O/S
    25-16-90-5 MK1 Chrome Bumper ( Front/Rear ) Fixing Bolts
    25-16-90-7 MK1 Front Bumper Brackets (1 pair) L/H
    25-16-90-8 MK1 Front Bumper Brackets (1 pair) R/H
    25-16-95-0 MK1 Chrome Rear Bumper
    25-16-95-1 MK1 Chrome Rear Bumper With Cut Out
    25-16-95-7 MK1 Rear Bumper Bracket L/H
    25-16-95-8 MK1 Rear Bumper Bracket R/H
    25-16-99-0 MK1 Front Aluminium Grille
    25-17-31-1 MK1 Standard Wing 4 Door L/H
    25-17-31-2 MK1 Standard Wing 4 Door R/H
    25-18-11-7 MK1 Bracket For Van Door To Saloon Door
    25-18-11-8 MK1 Bracket For Van Door To Saloon Door
    More to come in 2016.
    If you require prices PM me or post below.
    Many thanks
    Tim
    TJ Motorsport
    45 Allt Dderw
    Broadlands
    Bridgend
    CF31 5BZ
    http://www.tjmotorsport.co.uk
    Follow Me On Facebook
    Dec 2003
    birmingham
    189
    Re: Magnum Panels - Escort Mk1
    Hi
    Can you get the inner parts of the spring hanger separate?
    Jul 2004
    644
    Hello Mac
    Only available as the complete assembly as shown in the link below:
    http://www.tjmotorsport.co.uk/prodde...?prod=25168120
    Regards
    Tim
    TJ Motorsport
    45 Allt Dderw
    Broadlands
    Bridgend
    CF31 5BZ
    Jul 2016
    Ireland
    187
    Would you be able to get wheel tubs for a Mk1?
    Jul 2004
    644
    They are not available at the moment.
    Regards
    Tim
    TJ Motorsport
    45 Allt Dderw
    Broadlands
    Bridgend
    CF31 5BZ
    Mar 2008
    North Wales
    214
    10
    Please, please, please, please, please stamp headlamp repair panels (round lamps) for mk1 Escort
    Aaarrrrrrrgh ppplease.
