Results 1 to 1 of 1
Thread: Magnum Panels - Escort Mk2
    TURBOSPORT SPONSOR Turbosport Sponsor TJM's Avatar
    Jul 2004
    Bridgend, Vale Of Glamorgan
    643
    Hello to all
    Below you will see the current list of Magnum Panels for the Escort Mk2:
    25-16-06-1 MK1/2 Car Inner Sill 2/4 Door
    25-16-06-2 MK1/2 Car Inner Sill 2/4 Door
    25-16-06-1E MK1/2 Inner Sill No Cut Out Centre Channel ( Restoration Design )
    25-16-06-2E MK1/2 Inner Sill No Cut Out Centre Channel ( Restoration Design )
    25-16-07-1 MK1/2 Outer Sill To Floor
    25-16-07-2 MK1/2 Outer Sill To Floor
    25-16-20-06 MK1/2 Slam Panel Bracket ( Bonnet Catch )
    25-16-29-0 MK1/2 Spare Wheel Trough
    25-16-29-1 MK1/2 Petrol Tank Trough
    25-16-38-9 MK1/2 Heater Hose Cover ( Bulkhead )
    25-16-39-5 MK1/2 Splash Shield Stiffener ( Per Pair)
    25-16-43-8 MK1/2 Heater Box Bulkhead Repair Panel
    25-16-43-10 MK1/2 Fan Seal + Heater Pipes Seal in 6mm EPDM Sponge
    25-16-45-0 MK1/2 Under Wing Suspension & Side Panels To 1977
    25-16-45-1 MK1/2 Under Wing Suspension Support Pan Only To 1977
    25-16-45-2 MK1/2 Under Wing Kit To 1977
    25-16-45-OE MK1/2 Pan Support Reinforcements AVO/RS Type Per Pair
    25-16-69-0 MK1/2 Battery Tray ( Boot Type )
    25-16-74-3 MK1/2 Front Floorwell 2/4 Door
    25-16-74-4 MK1/2 Front Floorwell 2/4 Door
    25-16-74-5 MK1/2 Tunnel Cover
    25-16-74-6 MK1/2 Automatic Gear Box Tunnel Cover
    25-16-74-7 MK1/2 Large Gear Box Cover
    25-16-75-6 MK1/2 Gear Box Mounting Brackets
    25-16-75-7 MK1/2 Gear Box Tunnel Brace
    25-16-76-1 MK1/2 Rear Floorwell 2/4 Door
    25-16-76-2 MK1/2 Rear Floorwell 2/4 Door
    25-16-76-3 MK1/2 Rear Seat Brace
    25-16-76-5 MK1/2 Sill Closing Panel N/S
    25-16-76-6 MK1/2 Sill Closing Panel O/S
    25-16-76-8 MK1/2 Steel Bung For Floor Pans Small Hole
    25-16-78-0 MK1/2 Jacking Point Support
    25-16-81-1 MK1/2 Centre Chassis Section
    25-16-81-2 MK1/2 Centre Chassis Section
    25-16-81-5 MK1/2 Rear Chassis Section L/H
    25-16-81-6 MK1/2 Rear Chassis Section R/H
    25-16-81-5E MK1/2 Rear ATB Bracket N/S
    25-16-81-6E MK1/2 Rear ATB Bracket O/S
    25-19-76-0 Escort MK2 Seat Centre X Member (Formally 25-19-001)
    25-19-00-1 Escort MK2 Sill 2 Door
    25-19-00-2 Escort MK2 Sill 2 Door
    25-19-10-1 Escort MK2 Front Door Mirror L/H
    25-19-10-2 Escort MK2 Front Door Mirror R/H
    25-19-11-1 Escort MK2 Door Skin 2 Door
    25-19-11-2 Escort MK2 Door Skin 2 Door
    25-19-20-0 Escort MK2 Front Panel
    25-19-20-1 Escort MK2 Inner Front Panel Assembly
    25-19-23-1 Escort MK2 Lower Front X Member
    25-19-24-1 Escort MK2 Headlamp Mounting Panel
    25-19-24-2 Escort MK2 Headlamp Mounting Panel
    25-19-25-0 Escort MK2 Headlamp Bowl Plastic
    25-19-27-0 Escort MK2 Slam Panel
    25-19-31-1 Escort MK2 Front Wing 2 Door
    25-19-31-2 Escort MK2 Front Wing 2 Door
    25-19-32-0 Escort MK2 Scuttle ( 5 Fixing )
    25-19-32-1 Escort MK2 Scuttle ( 7 Fixing )
    25-19-37-7 Escort MK2 Front Brake Dust Cover
    25-19-37-8 Escort MK2 Front Brake Dust Cover
    25-19-38-0 Escort MK2 Lower Bulkhead ( Firewall )
    25-19-38-1 Escort MK2 Inner Wing Large Hole No Support L/H To 1977
    25-19-38-2 Escort MK2 Inner Wing Large Hole No Support R/H To 1977
    25-19-38-3 Escort MK2 Inner Wing Large Hole RS2000 ( Fully Dressed ) L/H
    25-19-38-4 Escort MK2 Inner Wing Large Hole RS2000 ( Fully Dressed )RL/H
    25-19-38-9 Escort MK2 Inner Wing Small Hole No Support L/H 1977 On
    25-19-38-10 Escort MK2 Inner Wing Small Hole No Support R/H 1977 On
    25-19-38-11 Escort MK2 Inner Wing Small Hole RS2000 ( Fully Dressed ) L/H
    25-19-38-12 Escort MK2 Inner Wing Small Hole RS2000 ( Fully Dressed ) R/H
    25-19-38-13 Escort MK2 Left Hand Drive Inner Wing Small Hole L/H
    25-19-38-14 Escort MK2 Left Hand Drive Inner Wing Small Hole R/H
    25-19-38-15 Escort MK2 Left Hand Drive Inner Wing Small Hole Dressed L/H
    25-19-38-16 Escort MK2 Left Hand Drive Inner Wing Small Hole Dressed R/H
    25-19-38-5 Escort MK2 Radiator Side Support
    25-19-38-6 Escort MK2 Radiator Side Support
    25-19-39-1 Escort MK2 Front Splash Shield ( A Pnl )
    25-19-39-2 Escort MK2 Front Splash Sheild ( A Pnl )
    25-19-39-5 Escort MK1/2 Splash Shield Stiffener (Per Pair)
    25-19-40-1 Escort MK2 Front Door Jamb L/H
    25-19-40-2 Escort MK2 Front Door Jamb R/H
    25-19-40-3 Escort MK2 Inner Door Jamb L/H
    25-19-40-4 Escort MK2 Inner Door Jamb R/H
    25-19-41-1 Escort MK2 Mounting Band
    25-19-41-2 Escort MK2 Mounting Band
    25-19-41-3 Escort MK2 Flitch Panel L/H
    25-19-41-4 Escort MK2 Flitch Panel R/H
    25-19-42-1 Escort MK2 Top Suspension Panel - 77
    25-19-42-2 Escort MK2 Top Suspension Panel - 77
    25-19-43-1 Escort MK2 Top Suspension Panel Feb 77-
    25-19-43-2 Escort MK2 Top Suspension Panel Feb 77-
    25-19-42-OE Escort MK2 Large Hole Strut Reinforcement RS Type
    25-19-43-OE Escort MK2 Small Hole Strut Reinforcement RS Type
    25-19-43-9 Ecort MK2 Heater Bowl
    25-19-45-0 Escort MK2 Under Wing Suspension Support With Sides 1977on
    25-19-45-1 Escort Mk2 Under Wing Suspension Support Pan Only 1977on
    25-19-45-2 Escort MK2 Under Wing Kit 1977 on
    25-19-45-1E Escort MK2 Underwing Support, Side Panel To Pan RS Type N/S
    25-19-45-2E Escort MK2 Underwing Support, Side Panel To Pan RS Type O/S
    25-19-51-1 Escort MK2 Rear 1/4 Panel L/H
    25-19-51-2 Escort MK2 Rear 1/4 Panel R/H
    25-19-55-1 Escort MK2 Inner Rear Wheel Arch
    25-19-55-2 Escort MK2 Inner Rear Wheel Arch
    25-19-55-1A Escort MK2 Rear Wheel (Boot) Tub Assembled L/H
    25-19-55-2A Escort MK2 Rear Wheel (Boot) Tub Assembled R/H
    25-19-55-3 Escort Mk2 Inner (Boot) Wheel Tub L/H
    25-19-55-4 Escort MK2 Inner (Boot) Wheel Tub R/H
    25-19-55-5 Escort MK2 Outer (Boot) Wheel Tub L/H
    25-19-55-6 Escort MK2 Outer (Boot) Wheel Tub R/H
    25-19-58-1 Escort Mk2 Rear Wheel Arch 4 Door
    25-19-58-2 Escort Mk2 Rear Wheel Arch 4 Door
    25-19-59-1 Escort Mk2 Rear Wheel Arch 2 Door
    25-19-59-2 Escort Mk2 Rear Wheel Arch 2 Door
    25-19-60-1 Escort MK2 Rear Lower Corner
    25-19-60-2 Escort MK2 Rear Lower Corner
    25-19-65-0 Escort MK2 Complete Back Panel
    25-19-68-0 Escort MK2 Lower Back panel
    25-19-69-0 Escort Mk2 Battery Tray
    25-19-69-1 Escort MK2 Battery Tray Support
    25-19-69-2 Escort MK2 Battery Tray + Support
    25-19-75-0 Escort MK2 Full Floor With Front & Rear Seat Brackets
    25-19-75-1 Escort MK2 Full Floor Skin No Brackets/Tunnel
    25-19-76-8 Escort MK2 Steel Bung Large Hole
    25-19-81-3 Escort MK2 Front ( Engine ) Chassis L/H
    25-19-81-4 Escort MK2 Front ( Engine ) Chassis R/H
    25-16-81-5 Escort MK1/2 Rear Chassis Section L/H
    25-16-81-6 Escort MK1/2 Rear Chassis Section R/H
    25-19-88-0 Escort MK2 Boot Floor Full Section
    25-19-81-OE Escort Rear Skid Panel
    25-16-81-5E Escort MK1/2 Rear ATB Bracket N/S
    25-16-81-6E Escort MK1/2 Rear ATB Bracket O/S
    25-16-81-5/6 MKI/2 Rear Chassis Section
    25-19-81-20 MK2 Rear Chassis Spring Hanger
    25-19-90-3 Escort MK2 Front 1/4 Bumper Chrome N/S
    25-19-90-4 Escort MK2 Front 1/4 Bumper Chrome O/S
    25-19-90-5 Escort MK2 Front 1/4 Bumper Black N/S
    25-19-90-6 Escort MK2 Front 1/4 Bumper Black O/S
    25-19-90-7 Escort Mk2 Black Bumper ( Front/Rear ) Fixing Bolts
    25-19-90-9 Escort MK2 Front Bumper Brackets (I pair)
    25-19-95-0 Escort MK2 Rear Full Bumper 1 Light Hole
    25-19-95-1 Escort MK2 Rear Full Bumper 2 Light Hole
    25-19-95-3 Escort MK2 Rear Bumper Chrome
    25-19-95-7 Escort MK2 Rear Bumper Bracket Per Pair
    25-19-98-1 Escort MK2 Rear Light N/S
    25-19-98-2 Escort MK2 Rear Light O/S
    25-19-98-3 Escort MK2 Rear Lens N/S
    25-19-98-4 Escort MK2 Rear Lens O/S
    25-19-98-5 Escort MK2 Rear Lens Restorer Quality L/H
    25-19-98-6 Escort MK2 Rear Lens Restorer Quality R/H
    25-19-99-0 Escort MK2 Plastic Grille Roundheadlight
    25-19-20-2 RS2000 Front Inner Panel
    25-19-23-2 RS2000 Front X Member
    25-19-31-3 RS2000 Front Wing L/H
    25-19-31-4 RS2000 Front Wing R/H
    More to come in 2016.
    If you require prices PM me or post below.
    Many thanks
    Tim
    TJ Motorsport
    45 Allt Dderw
    Broadlands
    Bridgend
    CF31 5BZ
    http://www.tjmotorsport.co.uk
    Follow Me On Facebook
