hi together,
after bearing failure (big end cyl. no.1) due to problems with oil-supply (sump, pump) my crank needs a re-grind:
its a 681 engine, with 711pistons and flat, stage 3 head, lightened flywheel, rear bowl sump, still on 681 round main bearing caps.
mains are actually on +.010
big ends are on +.010"
grinding all journals, plus nitriding 475pound (600,-€), fine balancing would be en top
difficult decision now...
