Results 1 to 15 of 15
Thread: Which intercooler?
    Sep 2005
    Herts
    90
    Which intercooler?
    Im thinking of up rating me intercooler now i have bigger turbo being put on the cab. Was just wondering which one to go for.
    which one would you go for? front mounted or the half size intercooler?
    is the bigger one def better?
    also pro alloy, pace or radtec???
    Bodger streetracersgd's Avatar
    Sep 2004
    Leicester
    69
    Re: Which intercooler?
    i would go for a front mounted intercooler as they are far more efficient the rad tec one fits very nice too
    Streetracers
    Rolling Road Tuning 01162767004 all mapping
    Omex & Wizards of nos agents
    www.streetracersgd.co.uk
    Sep 2005
    Herts
    90
    cheers for reply mate
    i think both the radtec and pro alloy one can bolt straight on with out chopping bumper? i dont want the bumper cut
    World Champion Decade Plus User markb's Avatar
    Feb 2003
    Plumstead
    6,821
    10
    definitely front mount... i had a GRS on my series one and didn't have to chop the front out. Personally i'd try to get one that was single pass though if you can.
    Sep 2005
    Herts
    90
    single pass through? lost me mate?
    i forgot about GRS gona have a lppk now
    Sep 2004
    Leicester
    69
    grs are very good but you just have to wait for them to be made lol but worth the wait some times
    Streetracers
    Sep 2005
    Herts
    90
    still dont know what to go for!
    cheers for help people! will let you know
    any one know what the single flow is??
    Feb 2003
    Plumstead
    6,821
    10
    basically single pass is when the air goes into the intercooler one end and exits the other. in the case of an rsturbo it means using a reverse charge carrier. unless they've changed the GRS is twin pass, but i think the new Pace one and the Radtec are single pass. (not 100% though!)
    Tyre Kicker Adam Hybrid RST's Avatar
    London
    17
    I'd go for a GRS front mount aswell mate, twin pass and bolt straight in. They're fitted to some fo the fastest RST's in the country.
    Ready for the summer .......
    Spanner Monkey tarmac terriost's Avatar
    Aug 2005
    truro cornwall
    450
    wheres the cheapest place to get a grs stage 4 intercooler from
    any other good coolers apart from pace /rad tec/pro alloy etc
    mrk 2 mondeo ghia saloon
    17" tsw reflexs bomz kit
    fast road cams/obx pulleys
    drop 30mm eibach springs mongoose catback exhaust
    4.1 ceramic coat exhaust manifold
    custom down pipe/highflow cat
    list to do :-
    st bodykit 300mm disc conversion+rear disc
    underdrive pulley custom management 45mm throttle bodies gasflown big valve head
    comp ratio increased 11:1
    looking for a mint 4x4 rouse motorsport 304r sapphire running std (260bhp) or stage 3 set up
    Aug 2005
    truro cornwall
    450
    a bit about coolers
    However, this is not the only solution and we produce two alternatives both of which offer improved ACT's over the GRS and similar items. Shown below are two such intercoolers for the Escort RS Turbo. These intercoolers utilise either two or three Sierra RS Cosworth Intercoolers welded together to form one huge intercooler capable of keeping Air Charge Temperatures as low as possible, and with almost zero pressure drop across the intercooler, it makes for an extremely efficient intercooler setup. It is not as straight forward as off the shelf bolt on unit's though, as it requires some modifications to fit, and makes fitting a large fan virtually impossible but is the ultimate intercooler for an RS Turbo. Please note that the triple version is only available for the S2 ERST, the S1 ERST has insufficient space without major remodeling of the front end!
    The twin and triple Cosworth intercooler conversion are single pass intercoolers which means the intercooler outlet is on the opposite side to standard. This requires the charge cross over pipe to be re-fabricated in order to complete the installation. We produce a mirror image of the original item giving a factory look but improved function!
    One major part of RS Turbo tuning which is commonly overlooked when tuning a car is the Air Charge Temperature cooling setup. The standard Intercooler on an Escort RS Turbo will only keep ACT's down to a satisfactory level (ie 50 degrees C or lower) with boost levels of no more than around 10psi. Most stage 1 RS Turbo's are chipped and are running between 15psi and 17psi of boost. This is all very well until you realise that the ACT's associated with these boost levels in conjunction with a standard Intercooler are excessive to say the least. They would be well over 70 degrees C almost straight away.
    As ACT's rise, power is lost due to the the air containing less oxygen than when the air is cool. An effective Intercooler will keep your ACT's ideally below 40-45 degrees C at all times, thus ensuring that maximum power is always available even in hot weather.
    Fitting a GRS Motorsport Large Intercooler to a Series 2 provides only one small problem, which is the radiator fan. Due to the size and location of the Intercooler, the standard Escort RS Turbo radiator fan can only be used if it is mounted on the front of the intercooler (therefore blowing through both the intercooler and the radiator). Most customers prefer not to mount anything on the intercooler for two reasons :- how it looks, and to not restrict air-flow to the intercooler. Therefore a solution has been found in the shape of a very thin radiator fan from Kenlowe. We can supply you the Kenlowe 10" Fan which is only 46mm thick, which fits in between the Intercooler and the Radiator at a discounted price. This solves any of the engine cooling issues when stuck in traffic.
    The GRS Motorsport Large Intercooler for the S2 has undergone some more design changes to make it an even more efficient product. The latest version of this Intercooler, named the "EVO 3" utilises a totally new core, which is even wider for better air flow and therefore reduced pressure drop. The volume of the Intercooler has also been increased by 17% allowing the air to pass through the Intercooler for longer therefore being further cooled. The end tanks on the Intercooler are also as matched in size as possible, again for the best possible flow.
    Caution must be given when fitting this intercooler as water temperatures may rise depending on ambient temperatures.
    Please check your radiator is in good working order
    list to do :-
    Apr 2006
    aberdeen
    11
    Here's a pic of pro alloy fmic (not fitted yet). With the pro alloy fmic you get the complete fitting kit , hoses etc .http://i64.photobucket.com/albums/h1...s83/car007.jpg
    World Champion Decade Plus User BIGJAY's Avatar
    Sep 2003
    ruislip middx
    7,083
    9
    u have better results with charge cooler
    Oct 2010
    long beach, california
    36
    Quote Originally Posted by streetracersgd View Post
    I agree with you bro, i had my tubro intercooler installed the same way. anyways, I will post a pictures and DIYs for it.
    romford essex
    2,613
    86
    pro alloy one i done the testing for it a few years back on altays car at burtons and it works lovely low charge all year round and fits a treat
Similar Threads
  1. Intercooler inlet/outlet sizing
    By Slymanrs2 in forum The Technical Section
    Last Post: 26-10-2005, 14:03
  2. mk1 escort intercooler
    By DanR in forum Cosworth Installations
    Last Post: 21-09-2005, 22:56
  3. Pro Alloy RS500 intercooler & radiator!!!!
    By BlakeyA in forum Parts For Sale
    Last Post: 30-08-2005, 23:04
  4. intercooler pipe blowing off turbo
    By PercyBigun in forum Message Centre
    Last Post: 22-12-2004, 21:07
