Does the accumulator pressure pump and servo need any special bleeding tools as I've bled it several times and pedal is not as hard as it should be
It does does not pump up if pushed several times either -
Did not bench bleed it or use vacuum pump to remove air so
Any suggestions other than start at the rear and half press the pedal with ignition on
