just wondered if any one can help,,just bought a standard 105e and was wondering about wheel and tyre choices,would cortina rostyles with 185/60/13 boots fit wthout rubbing front struts
You will need longer wheel studs and spacers.I fitted 5.5 lotus steels to mine with 185/60/13 tyres and the rubbed big time.Ended up using 15mm spacers.I'm now swapping over to mk2 cortina struts and all the associated parts you need to fit these.Never felt safe with such a large spacer.Would probably be better using a narrower tyre.
Cheers Russ
Will also be very tight to the front edge of the front wheel arch
cheers russ,might try 175/60's,think the wheels are only 5j so 175's should be plenty...cheers dave
