Results 1 to 6 of 6
Thread: Ford coil (EDIS module era) leads to suit XE
    Jun 2012
    ireland
    1,155
    Hi Folks, stupidly with so much other stuff going on i never actually checked if these would fit my setup, even though they have been sitting in a box for 6 months
    im running Megajolt on my XE with the EDIS module and Ford coil pack setup ( the one with the plastic clips to hold the leads onto the coilpack)
    however even with the rubber sealing rings shaved off the leads, theyre still marginally too short to reach the plugs, has anyone any recommendation on what to use XE-ford coil? i dont actually have any XE leads, so i dont know if they would fit in the ford coil pack properly ?
    many thanks
    Jun 2012
    ireland
    1,155
    Re: Ford coil (EDIS module era) leads to suit XE
    any suggestions guys?
    Holland
    32
    252
    32
    I had a similar problem and got this set. You can make them to your own length. They got plenty length to start with.
    They have high EMI resistance and low ohm resitance.
    http://www.ignitionproducts.eu/nl/ms...ctor-boug.html
    If you wanna go cheap, get ka leads and a coil that uses the push on cables.
    But the bit that connects to the spark plug isn't fully straight so a pain to get on spark plug
    Jun 2012
    ireland
    1,155
    super thanks! thats not too bad i guess, are they the exact connections for the ford coil? they look like they are, thanks!
    Holland
    32
    252
    32
    Yes they are a direct fit to the ford coil, because msd also reproduces them
    Jun 2012
    ireland
    1,155
    great thanks just ordered a set !
