Page 1 of 2 1 2 LastLast
Results 1 to 40 of 62
Thread: Time for a fresh un up
    Pit Crew Decade Plus User nickmk11's Avatar
    Sep 2004
    uk kent
    1,143
    thought it was about time i pulled it apart here is a few pics
    as you can see engine bay needs a lick of paint and a good tidy up
    MOBILE REMAPPING KENT
    Clint's Avatar
    Jul 2001
    943,849
    Re: Time for a fresh un up
    Nice one Nick, so any changes being made while its apart ?
    Sep 2004
    uk kent
    1,143
    new pistons ,full bottom end rebuild might have a polish up on a few bits ,new valves and guides new cams bd 14 inlet or both ?recheck head ports valve seats full core plug change chop a bit more off the flywheel 2 wd exhaust if i can get it in ,poss new turbo a bit bigger,500 manifold escort throttle body then save up[ for my ecu ,then a paint up engine bay and inside sort the axle out ,and another load of cash gone on the money pit,oh well its for a good cause ME
    clint whats you thoughts on the pistons in my engine with the washed area on the inlets ,i am not sure if it is because the pistons are quite oily so they look cleaner !
    Jan 2006
    southampton
    807
    is the green stuff in the water jackets in the block a rust treatment? if so where from and what is it called?
    would be interested to know more...
    cheers. pauly
    Sep 2004
    uk kent
    1,143
    Quote Originally Posted by mk1nurburg
    cheers. pauly
    no i am sorry to say it is antifreeze
    Clint's Avatar
    Jul 2001
    943,849
    All gueswork from just looking but I dont mind lloking silly if I am wrong LOL :
    It looks like its been running a bit on the rich side and maybe the squish is loose (guessing youve not been pussy footing it and that it still has hydraulic followers in, no piston to valve contact has me guessing the pistons arent as high as they should be).
    The exhausts look like they have had 3 angled seats cut or possibly loose guides resulting in poor seating and heat transfer, as they have quite successfully burnt the carbon white.
    Certianly not had any problems in there, are the bores good ?
    Dave's Avatar
    Oct 2003
    Cheshire
    19,588
    141
    What made you decide it was time for a freshen up?
    How do you decide these things, and how long was it since you last did it?
    What have you been doing with it in the meantime.
    I guess it isn't done as a regular 6k service, so is it something you have to do after a certain time or is it after a certain amount of punishment.
    Just wondering really as Clint has done the same to Smiffy's motor too.
    Dec 2003
    London
    10,228
    26
    Nick,your engine bay looks like all it needs a is a polish,not a repaint
    Dave,im thinking of having my engine out this winter for a check over,probably new bearings etc. Best to catch it early and not leave it years and years before a fresen up then having to pay out more and more money
    I think you know when its time to take it out,i think you can feel if its starting to feel tired and maybe starting to use a bit more oil than it used to. Mine seems to hardly use any oil and i never have to put any water in it,maybe im not driving it hard enough
    So thats why i decided not to have the engine out last winter as its ok at the moment (touch wood)
    Sorry to Hi-Jack the thread
    Sep 2004
    uk kent
    1,143
    the reason for rebuild is it is knocking when cold and i hate that ,got an oil leak from back of head block somewhere chuffs a bit of oil now ,so its time to save it before it chucks a rod through the side ,and and a few goodies i have been collecting so we can add a few more horses.
    clint the valve guides are worn and piston heights are the same, just polished the tops when machined the bowl, it has done the usual valve to piston on 1 and 4 ,the bores are std just hope 0.5 will do it .i am just thinking about pulling te bottm end out now ,but its sunday shall i or shan't i
    Clint's Avatar
    Jul 2001
    943,849
    Go on m8 get it done, you will feel better for it, other wise you will be all depressed as you havnt got anything done.
    Dave's Avatar
    Oct 2003
    Cheshire
    19,588
    141
    Thanks for the answers.
    Sep 2004
    uk kent
    1,143
    stripped the head and bits today for cleaning here is before pics as you all like pics more to follow
    oil bungs out for a good clean
    std 4x4 manifold with a crack
    escort t body to go on as well
    Jan 2004
    South Africa
    3,354
    20
    From what model escort is that TB ?
    Clint's Avatar
    Jul 2001
    943,849
    Quote Originally Posted by DarthVader
    Late Escort Small Turbo with EEC4 management.
    Sep 2004
    uk kent
    1,143
    had a bit of a polish up on the head this afternoon and stripped the cam cover for a new colour or two
    Jan 2006
    southampton
    807
    looking good!!
    what did you use initially to clean the head chambers and valves?
    keep up the progress.
    cheers. pauly
    Sep 2004
    uk kent
    1,143
    used emery flap wheels to get casting marks off then polish bits and alloy polish to clean up more
    took the ports out a bit more tonight to 27/8 mm on the inlet, exhaust are ok ,new valve guides to go in and cam then the head is done ,then on to the bottom end
    Jan 2006
    southampton
    807
    nice. cheers nick.
  19. #19
    Aug 2002
    Geordie Land
    2,232
    nick
    what is the heat shielding you used on the inner wing and wer did you get it from ?
    thanx steve
    MY MK1 ESCORT (Now turbo'd)
  20. #20
    Jan 2006
    paisley
    165
    Quote Originally Posted by Ripper
    nick
    thanx steve
    you can get this type of heat shielding from agriemech ltd(www.agriemech.com),called reflect-a-cool.used it on the alloy heatshield on my cosy.
    stuart
  21. #21
    Aug 2002
    Geordie Land
    2,232
    thanx m8ty ill buy some of that
    damm the link dont work have you any other link for that ?
    thanx steve
  22. #22
    Aug 2002
    Geordie Land
    2,232
  23. #23
    Sep 2004
    uk kent
    1,143
    rally design do it and advance 2"tape
  24. #24
    Sep 2004
    uk kent
    1,143
    Just had me bits dropped off back from the cleaners
  25. #25
    Sep 2004
    uk kent
    1,143
    Took the bottom end out today then stripped it down ,looks good after 5 years ,shells no wear at all really bores not to bad ,sent up to get bored today and crank up for a polish ,got to get rods off now cleaned up then get it all balanced ,take a bit more off the flywheel looks to heavy
  26. #26
    Dec 2003
    London
    10,228
    26
    Doesnt look too bad at all mate,keep up the good work
  27. #27
    Sep 2004
    uk kent
    1,143
    Got a few rebuild bits today now of to machine them ,
    and started to paint cam cover today ,phone cam
  28. #28
    Dec 2003
    London
    10,228
    26
    Coming along mate
  29. #29
    Sep 2004
    uk kent
    1,143
    gone for the red look now ,got a bit board with blue just wants a bit more polishing
  30. #30
    May 2006
    Maidstone
    102
    Is that speckled?
  31. #31
    Sep 2003
    Leicester, United Kingdom, United Kingdom
    1,058
    Quote Originally Posted by steve m
    Is that speckled?
    I dunno but it looks good coming along now
  32. #32
    Oct 2004
    get me on my beeper,beeper
    11,882
    looking good nick keep it up m8
  33. #33
    Bodger Bamma's Avatar
    Aug 2004
    Manchester, UK - Maryland, USA
    123
    How' you getting on with this mate?
    I need some inspiration to do mine.
  34. #34
    Jul 2004
    Norn Ireland
    58
    1,199
    what where the alloy bits cleaned in/with ?
    nice job btw
  35. #35
    Sep 2004
    uk kent
    1,143
    been a bit slow on this ,been diy ready for a new baby on the way ,should have the engine block and bits back next week with a bit of luck then get on with it ,need a bit of a kick to get me going
    as for the cleaning its done in a very fine wet blast machine no good for rusty bits but ally its the nuts just looks like new if not better
  36. #36
    Sep 2004
    uk kent
    1,143
    i got out to the garage today first time for months ,i wish i had more time
    so did a bit of chopping today
  37. #37
    Oct 2004
    11,882
    good to see you aint gonna leave it nick,good luck on getting it done m8
  38. #38
    Dec 2003
    London
    10,228
    26
    Now thats a hole
    Good luck with it mate
  39. #39
    Sep 2004
    uk kent
    1,143
    had another hour today ,thats twice in 6 months
    i never get time
  40. #40
    Oct 2004
    11,882
    how far you gonna move the engine back then nick
Similar Threads
  1. Fresh Blood
    By stupot in forum Introductions
    Last Post: 22-02-2006, 10:31
  2. Fresh Engine in Cosworth :o)
    By cossymax in forum General Car Banter
    Last Post: 03-08-2005, 18:34
  3. TWINK - 1:43 Fresh from the shop today
    By Willid1 in forum ScaleModeling
    Last Post: 21-09-2004, 10:11
  4. Fresh Pinto won't rev over 4000 rpm ???????????
    By Escortmk1 in forum X-Flow - Pinto - BDA and Twincam
    Last Post: 03-08-2004, 22:23
