This is my car when i got it.I have now finished the roof panel and will put some photos up later
This is what im aiming for when finished .....
regards mark
regards mark
looks good should stick with the yellow... im only saying that because i was going for the Silver with a the mexico stripe down the side with out the mexico name
but still... looks great and good luck
Ant
Here are the photos of the roof panel.i bonded and riveted a piece of steel the width of the car and then filled it in.
regards mark
Looks good mate. Nice colour too!
Ant you can get them stripes with anything written instead of mexico, I was thinking of 1300 Sport myself...
- Lee
Ive been busy today,got quite a bit stripped down and hopefully will be nearly done tomorrow evening.
regards mark
nothin like strippin a car out great fun!! looks good and solid and the roof looks loads better now
Looking good, also looks like you have one of them atlas style escort axles...are they koln's????
It's a normal English from what I can see.Originally Posted by dangerousdave
Edit: spotted the one you mean now Dave.
Not with a rear loading diff dave?
Looks like an Atlas.... the Koln's dont have the top and bottom bolts running down the centerlineOriginally Posted by dangerousdave
aye i was looking for something along the lines of thisOriginally Posted by Lee S
Ant
Im hoping its a atlas.....i was having a browse through my local scrappy and came across a 1975 3 litre capri.i got the axle for Ģ35 and Ģ5 to remove it trouble is,when i compared the half shafts, the standard mexico ones were thickerOriginally Posted by Retromotorsport
regards mark
Ive been very busy the last couple of weeks..... i bought a bosch electric scraper and have been attacking the underside to get it back to bare metal.Trouble is,your hand goes numb after a hour on the scraper but i will get there in the end
regards mark
top stuff ive still got that job to go my self but lucky im cutting the floors out so thats some underseal i wont have to worry about
Ant
looking good but buy some anti vibration gloves from the builders merchant otherwise you,l end up with white finger vibration not good,and permanant just a hint,good luck
looking good there dood
MY MK1 ESCORT (Now turbo'd)
After 5 months of sitting in my lock up,with the occasional scrape at the paint,i have decided to have it sandblasted i found a place local to me who are blasting it and coating with a zinc primer for Ģ450...they have a good reputation and i cannot wait to get it back,photos will be put up soon
regards mark
I went to the sandblasters today to get some photos its a bit cheesey in places
regards mark
had a bit of work but looks like a good un to me m8,mine was worse than that when i got it back from the sandblasters m8 ,keep the pics coming tho
yeah its had alot done to it but it looks bloody solid
Ant
Hi all
yes she is a good'un and fairly solid but has had a bit of welding...i expect that there are lots of minters running around that are a lot worse than this underneath the paintwork but i know there is no rust in mine
regards mark
Did you have the body blasted as well ? What sort of blast did they use & what sort of pressure ?
I remember getting a Mk2 shell blasted that had a weld in cage in it, the lad blasted the cage and buckled the roof !!!
Hello all,
can anybody tell me what type of frontseats are on this pic? Are they original mk1 seats?
I have the same in my garage but donīt know to wich car they belong.
Regards from Germany, Thorsten
think they are Mk2 escort RS2000 roll tops .
Yep mk2 Rs rolltops.
Hi mate, looks sweet, good base there for you to work on.
Can you elaborate on the roof skin replacement for me a bit? Did you remove the old one and re spot weld new one in and do you have any more pics of this? Its something mine needs so interested to see it done.
