Originally Posted by
MegatronUK Currently attempting to wire up the Corsa switchgear on the column to the Escort lighting and wipers/washers. I'm starting from scratch with the Escort wiring, so that's not a problem, but I can't find any diagrams of the pins of the Corsa stalks. The
THe indicator stalk (which controls indicators, dip/main beam and pull to flash) has the following:
30 Permanent Live
49a Feed from flasher unit
49aR Indicator R
49aL Indicator L
58R Sidelights R?
58L Sidelights L?
P
56 Feed from light switch (as a Corsa has a separate rotary light switch)
56a Main Beam
56b Dip Beam (so 56 and 56b are connected when the stalk is in the normal position)
The wash/wipe stalk (intermittent wiper, pull to wash/wipe, push to wash/wipe rear) has:
J
W
53 Single speed
53e Self park
53a Live feed from fuse for wipers
53b Double speed
53h Maybe washer pump
WH
31 Earth for self park
I don't particularly fancy using a continuity tester on every combination of pins; there are potentially dozens for each stalk. Someone must have used them before?
