The ongoing saga of my Pinto Turbo project.
(sometimes wish I hadn`t bothered)
I took advice on here and removed the Cossie injectors,
standard ones are now back in place and after replacing
the brand new plugs with brand new plugs there is a
definite improvement but it`s still not good.
It starts to boost then sort of hesitates and seems to
hold back and wont boost at all really you only know there`s
a turbo there cos of the dump valve.
Airflow meter was fannyed around with when Cossie injectors were
fitted more tweeking has ensued. Started smoking on tickover ,
think Turbo seals are knackered, compression test was fine.
Even so surely it should still boost performance to some degree
even with less than perfect seals.
Any ideas gratefully received.
Allan
