Results 1 to 13 of 13
Thread: LSD settings
    May 2013
    Maidenhead, Berkshire
    193
    LSD settings
    I've looked at a few threads but I till don't feel I have the relevant information to decide which ramp settings. Looking at buying a Salisbury 3j LSD which comes in 45/45 or 30/65 ramp angles. I'm going to use the car for road rallies etc, so can anyone give some guidance. I know that driving style comes into play but if you can tell me the characteristics then it'll help. Car will have a relatively standard pinto.
    25,116
    Re: LSD settings
    45/45 will behave the same on and off throttle, so a big boot full will lock it and the rear is more likely to step out with a sharp lift of throttle. 30/65 would lock up easier under power but less likely to send the tail sliding when you lift
    4,892
    Re: LSD settings
    What type of LSD and also what setting to use is just like selecting a woman.
    You won't know what you like until you tried them all yourselves.
  4. The Following User Says Thank You to Miniliteman For This Useful Post:
  5. #4
    3,241
    Re: LSD settings
    And just like with women, it can be an expensive selection process LOL!
  6. The Following User Says Thank You to katana For This Useful Post:
  7. #5
    Re: LSD settings
    And just like with a woman an expensive experience too.
    If I were you I would go for the old tried and tested ramp angles and pre load settings if in doubt, they have served competitors well for many years.
  8. #6
    25,116
    Re: LSD settings
    i personally would prefer 35/65 but have done a lot of racing on 45/45
    if you have never had an lsd before then i would suggest 45/45
  9. #7
    Oct 2008
    whitley bay
    2,436
    89
    Re: LSD settings
    I use 45 45 as I like the car to feel loose when braking into tight stuff like sharp 90 junctions that get used a alot on road rallying also on the loose it's good for getting the front turned in
    My dad's car uses 30 60 and I find it isn't as easy to set up to slide but he prefers it this way
    So as said before it depends on what you want from the car
    Isn't there a diff that give both options being made now?
    Hexham and District Motorclub
  10. #8
    Apr 2012
    glasgow
    500
    17
    Re: LSD settings
    with the 3j nxg diff you can buy all sorts of rings with different ramp angles and they are double sided allowing two sets of ramps on one ring
    Keep her lit
  11. The Following User Says Thank You to cosworth4door For This Useful Post:
  12. #9
    Oct 2008
    whitley bay
    2,436
    89
    Re: LSD settings
    I thought I had seen them somewhere
  13. #10
    May 2013
    193
    Re: LSD settings
    I'll go with the 45/45 for now, can always change it in the future.
  14. #11
    Dec 2009
    Newtownards, County Down, Northern Ireland
    86
    Re: LSD settings
    I went with a 35/35 (maybe 30/30 can't remember) with medium preload 3J NXG diff, I got it as a drift day, track day, road car do everything diff. It's perfect. It was noisy as hell at the start but it bedded in fast and is perfect now its silent unless parking in a car park.
    Will
  15. #12
    Jan 2017
    Victoria australia
    16
    Re: LSD settings
  16. #13
    Spanner Monkey 76PINTO's Avatar
    South Wales
    237
    Re: LSD settings
    Titan traction master come with 2 interchangeable ramp angles... Very nice diff.
