Hello as per the title,
I've just purchased a replacement YB motor complete.
This engine has all the ancillaries attached including the power steering pump.
My question is as I've got electric power steering in the Mk2 I'm going to remove this item.
Anyone know of who makes or sells a shorter Poly V belt to suit.
My previuos setup was the the same as the Mk2 RS2000 of a lower alloy bracket and tension bar and a single V fan belt (that engine is no longer viable due to a fire).
Or a suggestion as to the best route to take with this.
Your help is most appreciated.
Adrian
