Results 1 to 7 of 7
Thread: Pierburg Solex EEIT 35 floating
    Jul 2013
    Danmark
    25
    Duck Pierburg Solex EEIT 35 floating
    Hi guys:-)
    I have recently bought a Transit mk2 2.0LC pinto :-)
    It was fitted with a VV carb, where the choke system was dismantled, and the cam was worn down.
    So I fitted a 2.0 cam and a 4/2/1 exhaust manifold, together with the new carb. Now I pulls so much better :-)
    But when idle, the carb is floating over, and when i look down thru it, I can see, fuel dripping out of the main jet, and down on the throttle valve. I is an Pierburg Solex EEIT 35 from a Cologne 2.3 V6. With the original jets, so fare... When I start it, with the lid of, and i watch the needle valve, it seems to close fine. So I suspect the float level to be to high? But I can't find any data, on how high the level should be... Any other suggestions is much appreciated as well :-)
    Best regards
    Chris Denmark
    4,888
    Re: Pierburg Solex EEIT 35 floating
    Chris,
    original jets will be fine for the 2.0 Pinto.
    Float level is 11.0 +/- 0.5 mm for this carb.
    Regards, Leon.
    Jul 2013
    Danmark
    25
    Thanks Leon Is the height measured to the top of the surface , where the lid is laying on? And is it the top of the float I measure from?
    Jul 2013
    Danmark
    25
    Anyone know the pressure for a VV carb and the Solex? I think the pump is giving to mutch fuel...
    4,888
    Quote Originally Posted by Chris Jacobsen View Post
    Guess it is the same as for the Weber carbs.
    Fuelpressure for any carb is the same; about 0.3 bar although a needle valve should be able to handle alot more.
    Jul 2013
    Danmark
    25
    Now I have adjusted the height to 11mm from float top to lid "edge" and the needle valve is now closing - so far so good But it still has a uneven idle - it goes up and down in rpm, and it squrits fuel out of the small brass pipe in the venturi, when the idle gets low I don't have any drawings of the carb, but is that from the acceleration pump?
    4,888
    Uneven idle could be a air leak near the inlet manifold.
    Don't know that Solex carb but if it's a vacuum operated acceleration pump then when the idle goes low the vacuum goes away and pump squirts a bit of fuel and idle goes up again.
Tags for this Thread
