Now i've fitted the electronic dizzie to my cross flow can i open the gaps up on my plugs?
Will it be an advantage?
And if so what gap?
Cheers in advance matt
And if so what gap?
leave the gaps alone!
a bigger gap produces a longer lasting higher voltage but weaker spark, smaller gap shorter fatter spark, some engines have a prefernce but in the main stick to std, unless you run fancy expensive small tipped plugs big gaps are asking for missfires.
with modern std emission lean running engines a long spark duration is probably a good thing, it give the mixture more change to burn, but away from that i cant see any good reason to open up plug gaps, it just put s the whole of the HT system under more load and your more likely to have caps rotors and leads break down.
the more mixture you have in compressed in a cylinder and the higher pressures be it either a high c/r or lots of turbo boost the more voltage it takes to fire the plug, which is why high power turbo and very high spec atmo engines run small plug gaps
http://www.championsparkplugs.com/ch...nition+systems
set gap at 1mm
why? never seen a gain on the dyno only missfires from too big a plug gapOriginally Posted by RMinOZ
so whats the preference for the x flow and pinto running an electronic dizzy;Originally Posted by graham bahr
and what gap do you reccomend for a pinto on electronic ignition
Regards,
Kevin
std!
0.6mm 0.025"
standard gap if you want your car to start in the morning
