Results 1 to 13 of 13
Thread: Pinto Spark Plug Adaptors
    Clint's Avatar
    Jul 2001
    800,307
    An absolute must for any tuned pinto, this is one of the key items used in a HT Pinto and ensures the ignition dosnt break down when the engine is tuned.
    These are normally only available to customers of HT Racing and thier customers, and thier customers, customers, friends and family and local farmers......
    I have convienced then to sell them separately.
    The satandard pinto plug is very poor quality and suffers from heat problems, these adaptors allow the use of motorcycle plugs and allow the choise of many different heat ranges.
    A set of Adaptors delivered to your door 40 pm me if interested.
    UK Mahle and Reinz Distributor - 3J Driveline Dealer - Corbeau Seat Dealer
    [B]Engine Parts for most makes, all Ford parts kept in stock, Pinto, Xflow, YB, V4, V6, Zetec, Dratec, Wiring Looms Plugs, Plug Kits and Loom Products, Head Refurbishment and Porting, Engine Rebuilding Services.
    Racer Decade Plus User Stevie's Avatar
    Aug 2002
    Geordie Land
    2,485
    Re: Pinto Spark Plug Adaptors
    whats the heat range do then m8 for us un educated people ?
    MY MK1 ESCORT (Now turbo'd)
    Moderator+ Decade Plus User
    dangerousdave's Avatar
    Oct 2002
    London
    18,258
    81
    Pretty sure when you tune an engine you need to use a colder plug as more power = more heat and so if you use a standard plug in a mad engine it will break down (and sometimes melt and hole pistons???)
    23,927
    236
    yes basically the more you tune an engine the hotter the combustion chamber temps if the plug is too hot ( some would say soft) at best it starts the breakdown electrically and you get a missfire at worse it can either start glowing and causing pre ignition or even melt its electrode, either can cause major engine failure.
    if you go the otherway and use a plug too cold (or hard) it wont stay clean and missfires are likely to result.
    engines in a mild state of tune should stick with the standard plug grade highly tuned but not full on competition engines one grade harder plug is usually best.
    the best and only real way to sort the correct plug grade is to get your engine set up properly so you know the full power mixture is spot on, then find the plug grade with gives the ideal rich tea biscuit colour on the insulator
    full monty competition engines can be a real swine to get the right plug for, quite often the grade required for race use is just to cold for starting and slow speed work, a which is why you find a fair few racers fit std plugs to warm up engines and run around the paddock and scruitineering with and only put race plugs in before they go out on circuit.
    high boost turbo cars can be even worse, needing very cold plugs for flatout running but are quickly fouled when they are not running flatout due to the very rich mixtures they tend to run, i went through 4 different types and several differnt plug gaps before i found what worked in my motor, even then i have to avoid too many cold starts without driving it hard or it will strat missfiring and the only cure then is a new set of plugs
    23,927
    236
    Quote Originally Posted by Clint
    i guess theres a second hidden benifit, less danger of the pistons hitting the side electrode on engines with heavily skimmed heads and pistons high up in the block.
    Racer Decade Plus User Mr_Hoarder's Avatar
    Sep 2001
    51
    2,811
    I have a set of these in my Pinto , it uses plugs from a Yamaha R6 !!
    www.RWD-Escort.co.uk
    I was a TS overhauler
    Aug 2002
    Geordie Land
    2,485
    are theses good plug for a pinto turbo out of a r6 ?
    Clint's Avatar
    Jul 2001
    800,307
    Give Ht a call m8 click thier logo on the banner at the top of the page.
    Dec 2004
    Funny Farm S.E London
    764
    Clint, do i get them from you or HT?
    Clint's Avatar
    Jul 2001
    800,307
    Hi Red Ht's m8 tell aaron I sent you
    Dec 2004
    764
    right you are
    Spanner Monkey carpmart's Avatar
    Jul 2005
    J12 M1 in Beds
    51
    436
    Hi Guys
    If you are reading this then I would appreciate your advice as per the thread here http://www.turbosport.co.uk/showthread.php?t=109530
    Harvey
    Jun 2012
    uk
    i have a mk2 rs2000 with twin 45s rc1 cam recurved dist and electronic ignition i have some plugs denso X24EPR-U9 with the the adaptors what would anyone recomend for the plug gap thanks just as they come or adjust
    __________________
  1. spark plug gapping
    By mk1matt in forum X-Flow - Pinto - BDA and Twincam
    Last Post: 26-05-2006, 18:42
  2. Spark plug recommendation?
    By IanD in forum The Technical Section
    Last Post: 15-03-2005, 11:22
  3. spark plug gap
    By peter66uk in forum The Technical Section
    Last Post: 17-03-2004, 20:05
  4. spark plug selection
    By wightie in forum Cosworth Installations
    Last Post: 10-09-2003, 15:04
  5. How do you adjust a spark plug ?
    By Joris in forum The Technical Section
    Last Post: 28-08-2002, 04:29
