Page 2 of 6 FirstFirst 1 2 3 4 5 6 LastLast
Results 41 to 80 of 210
Thread: Escort Mk1
  1. #41
    Jul 2016
    Ireland
    187
    Re: Escort Mk1
    Rear Panel Repair - Cont
    The rear panel support has been removed from the new rear panel
    And the support from the donor car cut out - to be fitted onto the new rear panel
  2. #42
    Jul 2016
    Ireland
    187
    Re: Escort Mk1
    The original bracket is a much better job than the one from the pattern part - it has tabs to secure it to the boot floor - which were missing from the pattern part.
  3. #43
    Jul 2016
    Ireland
    187
    Re: Escort Mk1
    Passenger Side Splash Panel
  4. #44
    Jul 2016
    Ireland
    187
    Re: Escort Mk1
    Dash Replacement
    The old dash has been removed from the shell
    And the replacement dash from the donor has also been removed
    The replacement dash is now off to be media blasted - and then needs a small repair before fitting.
  5. #45
    Nov 2008
    Adelaide, Australia
    1,331
    96
    Re: Escort Mk1
    You are going to end up with a lovely straight car me thinks! That is a nice jig/table that he is using. Definitely worth a go if I do another Escort although not sure where all the datum points come from given these cars had tolerences in inches!
  6. The Following 2 Users Say Thank You to MK1_Oz For This Useful Post:
  7. #46
    May 2010
    london
    1,139
    Re: Escort Mk1
    coming on strong...nice one...cheers mark
  8. The Following User Says Thank You to madragon199 For This Useful Post:
  9. #47
    Re: Escort Mk1
    I bet the donor car could have been restored by you as well
  10. The Following User Says Thank You to wildo105e For This Useful Post:
  11. #48
    Jul 2016
    Ireland
    187
    Re: Escort Mk1
    Work continued on the replacement dash
    The drivers side A pillar is slightly in the wrong position so a porta power is used to 'push it to the correct place.
    With adjustments made the replacement dash is test fitted
  12. #49
    Jul 2016
    Ireland
    187
    Re: Escort Mk1
  13. #50
    Jul 2016
    Ireland
    187
    Re: Escort Mk1
    Drivers Side A-pillar repair
    The A-pillar is made up of three parts.
    Inner Door Jamb - number 5
    Door Hinge Panel - number 3
    These panels sandwich the A pillar (number 9) which has the door hinges and door check strap attached to it.
    Because of previous repairs the inner panel is pretty knackered - this panel is not available to buy - so a new one is fabricated.
  14. #51
    Jul 2016
    Ireland
    187
    Re: Escort Mk1
    Upper Door Hinge
    Rear of upper Door Hinge
    Lower Door Hinge
    Rear of lower Door Hinge
  15. #52
    Jul 2016
    Ireland
    187
    Re: Escort Mk1
    Door Check Strap
  16. #53
    Jul 2016
    Ireland
    187
    Re: Escort Mk1
    Next Job is to fit the two outer panels that sandwich the A-pillar
  17. #54
    Jul 2016
    Ireland
    187
    Re: Escort Mk1
    The pictures don't do it justice - it really is worse in real life.
    If I had a limitless budget it may have been saved but I don't see the sense in throwing 30K at a 20K car !!
    This car has already cost more than I had hoped!!
  18. #55
    Dec 2009
    Netherlands
    413
    19
    Re: Escort Mk1
    Haha True though, some excellent work is shown here
  19. #56
    Jul 2016
    Ireland
    187
    Re: Escort Mk1
    This forum wont allow posts to be edited - I've just found pictures of the hinges before being welded onto the new A pillar - so I'll just add them here -
  20. #57
    Jul 2016
    Ireland
    187
    Re: Escort Mk1
    Drivers Side A Pillar repair Cont -
    All three panels in their correct positions.
    The splash guard is also fitted.
  21. #58
    Jul 2016
    Ireland
    187
    Re: Escort Mk1
    Due to previous accident the original A pillar was not quite square.
    This was highlighted by the jig.
    Not only were the door hinges in the wrong place but the gap between the jig and the top and bottom hinges were different.
    Before repair
    After Repair
  22. #59
    Sep 2014
    middlesbrough
    320
    Re: Escort Mk1
    very informative thread, great build loving all the pics
  23. The Following User Says Thank You to andy-v For This Useful Post:
  24. #60
    Jul 2016
    Ireland
    187
    Re: Escort Mk1
    Test Fitting the Doors
    As both a-pillars have been repaired, the hinges will have moved, so before going any further best make sure the doors sit/close properly.
    Drivers Door
    Passenger Door
  25. #61
    Jul 2016
    Ireland
    187
    Re: Escort Mk1
    The replacement rear tubs have arrived so along with the replacement dash and rear shelf are off for sand blasting before fitting.
  26. #62
    2,659
    268
    Re: Escort Mk1
    Quote Originally Posted by Perry Oaks View Post
    Drivers Door
    Passenger Door
    Nice... Gaps and shut lines look pretty spot on..
  27. The Following User Says Thank You to rallyrob For This Useful Post:
  28. #63
    Jul 2016
    Ireland
    187
    Re: Escort Mk1
    Fingers crossed the shut lines will stay that way when I fit the door rubbers!!
  29. #64
    Oct 2008
    whitley bay
    2,436
    89
    Re: Escort Mk1
    Superb work
    What a good reference this will be for anyone doing a mk1
    Hexham and District Motorclub
  30. The Following User Says Thank You to mexicotait For This Useful Post:
  31. #65
    Jul 2016
    Ireland
    187
    Re: Escort Mk1
    Doors from the inside -
  32. #66
    Jul 2016
    Ireland
    187
    Re: Escort Mk1
    The Dash, axel, rear panel and tubs are back from sandblasting
  33. #67
    Jul 2016
    Ireland
    187
    Re: Escort Mk1
    The media blasting has shown up a few problems with the rear panel and tubs which will need sorting.
    The water gully behind the grills in the rear flitch plate also needs work.
  34. #68
    Jul 2016
    Ireland
    187
    Re: Escort Mk1
    The replacement tubs although in really good condition need some work
  35. #69
    Jul 2016
    Ireland
    187
    Re: Escort Mk1
    Meanwhile work has continued on the front - drivers side inner wing replaced
    Just passenger side inner wing to fit then the rest of the front will be fitted.
  36. #70
    Jul 2016
    Ireland
    187
    Re: Escort Mk1
    Anybody know what these holes in the rear parcel shelf are for -
    I thought the middle hole was for a single speaker?
  37. #71
    9,204
    Re: Escort Mk1
    brilliant thread are those jigs available in halfords
  38. The Following User Says Thank You to alladdin For This Useful Post:
  39. #72
    May 2009
    Maesteg South Wales
    2,041
    142
    Re: Escort Mk1
    Great job
  40. The Following User Says Thank You to evans2822 For This Useful Post:
  41. #73
    May 2010
    london
    1,139
    Re: Escort Mk1
    nice work...no idea on the holes....cheers mark
  42. The Following User Says Thank You to madragon199 For This Useful Post:
  43. #74
    Jun 2006
    Durham, UK
    1,494
    Re: Escort Mk1
    I don't know, but mine has them too:
    I guess they're part of the standard panel pressing. They do look vaguely speaker-hole-ish, but I can't imagine rear speakers would ever have been something Ford would have had the foresight to make space for in the mk1.
  44. The Following User Says Thank You to MegatronUK For This Useful Post:
  45. #75
    Jul 2016
    Ireland
    187
    Re: Escort Mk1
    Quote Originally Posted by MegatronUK View Post
    I thought the square holes are just part of panel design but the centre hole - I thought early 70's no stereo only mono radio so only one hole needed....maybe?
  46. #76
    Jul 2016
    Ireland
    187
    Re: Escort Mk1
    Work is progressing well on the front end -
    Both inner wings fitted -
    Strut Reinforcement Panels test fitted -
  47. #77
    Jul 2016
    Ireland
    187
    Re: Escort Mk1
    Wing Filler Panels - test fitted
  48. #78
    Jul 2016
    Ireland
    187
    Re: Escort Mk1
    These panels haven't been welded in place as its been noticed that the replacement magnum inner wing panels have some problems.
    This is an original ford inner wing - note the 90 degree angle on the wing mounting band.
  49. #79
    Jul 2016
    Ireland
    187
    Re: Escort Mk1
    Now compare that with the new inner wing panels -
    Unless sorted the wings will not sit properly on the mounting band and any errors will be really noticeable at the shut lines.
  50. #80
    Jul 2016
    Ireland
    187
    Re: Escort Mk1
    New Battery Tray fitted
    Front Inner Panel fitted
