Page 3 of 6 FirstFirst 1 2 3 4 5 6 LastLast
Results 81 to 120 of 210
Thread: Escort Mk1
  1. #81
    May 2010
    london
    1,139
    Re: Escort Mk1
    great write up as always..look forward to the next..cheers mark
  2. The Following User Says Thank You to madragon199 For This Useful Post:
  3. #82
    Bodger Gyver's Avatar
    Dec 2008
    Stockholm, Sweden
    35
    141
    I have mk1 that had a speaker mounted in that rear centre parcelshelf hole. Seemed like a factory fitted item.
    It's a german made 1974 1300l.
    Great thread btw!
    /David
  4. The Following User Says Thank You to Gyver For This Useful Post:
  5. #83
    Jul 2016
    Ireland
    187
    Re: Escort Mk1
    Firstly Seats and Capri 2.8i Struts have arrived.
    The struts will be converted to coilovers.
  6. #84
    Jul 2016
    Ireland
    187
    Re: Escort Mk1
    The entire front has now been test fitted to the car - ready for welding -
  7. #85
    Jul 2016
    Ireland
    187
    Re: Escort Mk1
    A fair amount of work has gone into ensuring the wings sit correctly on the car.
    Firstly the inner wing mounting rails were at the wrong angle - these were 'tapped' into the correct position.
    The self tapping screws are used to hold the wing in position as 'adjustments' are made. These will be removed once the wing is welded into its final position.
  8. #86
    Jul 2016
    Ireland
    187
    Re: Escort Mk1
    Then between the inner wing rail and front of the car sits the Wing Filler Flitch panel.
    This made the wing sit proud - so some work was need to ensure it all fitted correctly.
  9. #87
    Jul 2016
    Ireland
    187
    Re: Escort Mk1
    Some work was also needed where the wing meets with the front panel.
    It was the same on both sides
  10. #88
    Jul 2016
    Ireland
    187
    Re: Escort Mk1
    There is a slight bulge on one of the wings that needs sorting
    The time spent ensuring all the panels fit correctly was well spent - as the gaps between the bonnet, doors etc. are fairly consistence - with only minor adjustments now needed
  11. #89
    Jul 2016
    Ireland
    187
    Re: Escort Mk1
  12. #90
    Jul 2016
    Ireland
    187
    Re: Escort Mk1
    Bit of a crappy update but spent the day cleaning the wiper motor -
    Finished article -
  13. #91
    Jul 2016
    Ireland
    187
    Re: Escort Mk1
    Now that we're happy with the panel alignments and gap lines time to start the mammoth task of welding all the panels in place.
    Firstly boot Floor and rear turrets welded in position.
  14. #92
    Jul 2016
    Ireland
    187
    Re: Escort Mk1
    Next the rear panel.
  15. #93
    Jul 2016
    Ireland
    187
    Re: Escort Mk1
    The media blasting also uncovered a few problems with the rear corner which needed repairing.
    Some small patches were used to fill the holes
  16. #94
    Jul 2016
    Ireland
    187
    Re: Escort Mk1
    Discovered another problem with the pattern part rear panel.
    The rear bumper brackets mounting points will need some work to line up correctly.
    Luckily we have an another Escort that we can use to ensure that we are placing the brackets in the correct place, so definitely a pattern part problem.
  17. #95
    Jul 2016
    Ireland
    187
    Re: Escort Mk1
    Next the Inner front panel is welded in position.
  18. #96
    Jul 2016
    Ireland
    187
    Re: Escort Mk1
    Next the AVO Side Support for the Inner Wings are welded into position
  19. #97
    Spanner Monkey QuIcKrAcK's Avatar
    Jan 2007
    LONGFORD IRELAND
    204
    Re: Escort Mk1
    Lovely work that.
    Not done in ten minutes either.
    Will be a sweet shell
    1700cc MK1 ESTATE DONE. MK1 2DR STARTED
  20. The Following User Says Thank You to QuIcKrAcK For This Useful Post:
  21. #98
    Jul 2016
    Ireland
    187
    Re: Escort Mk1
    AVO Side Support finished
    Inner front panel Finished
  22. #99
    Jul 2016
    Ireland
    187
    Re: Escort Mk1
    Next the AVO Strut Reinforcement plates
  23. #100
    Jul 2016
    Ireland
    187
    Re: Escort Mk1
    And the other side -
  24. #101
    Jul 2016
    Ireland
    187
    Re: Escort Mk1
    Heater Bowl
    Windscreen washer bottle bracket welded into place.
    Bowl and bulk head behind the bowl will be primed and sprayed the final colour before being welded into position.
  25. #102
    Jul 2016
    Ireland
    187
    Re: Escort Mk1
    Back to Boot!!
    Stone Guard Bolts Fitted
    Bumper boot floor brackets welded in.
    Test Fitted Bumper - with no alignment problems
  26. #103
    Sep 2014
    middlesbrough
    320
    Re: Escort Mk1
    cracking job
  27. The Following User Says Thank You to andy-v For This Useful Post:
  28. #104
    Feb 2016
    Vila de Cruces Galicia Spain
    21
    Re: Escort Mk1
    Amazing job!, i love it
  29. The Following User Says Thank You to CEARACING For This Useful Post:
  30. #105
    Jul 2016
    Ireland
    187
    Re: Escort Mk1
    Right firstly checklist of remaining panels to fit -
    pair of rear wheel tubs
    rear outer wheel arches
    pair of outer sills
    pair of outer boot pockets
    weld on front panel
    prime seam seal and paint underneath innerwings
    final alignment and weld on front wings
    open up rear scuttle and carry out repairs to the inner part of it
    re fit outer part of rear scuttle
    re fit rear parcel shelf
    fit rear seat brace
    fit pair of front seat x members
    fit main dash panel
    have a good poke at both doors and final fit
    do a job on both b pillars at lock area
    fit bump stop bracket
    fit exhaust hanger
    fit seat belt threaded plates x 3 off
    fit axle and align tramp bar kit
    trial fit engine and box 5 speed conversion
    fit compression strut brackets
    drill a few holes
    it should then be ready for wheeling away to the paint shop....(hopefully!!)
  31. #106
    Jul 2016
    Ireland
    187
    Re: Escort Mk1
    Next the Front Panel is welded in position
  32. #107
    Jul 2016
    Ireland
    187
    Re: Escort Mk1
    Then two pac primer applied to the front and inner wings
    and behind the new wings
  33. #108
    Jul 2016
    Ireland
    187
    Re: Escort Mk1
    Rear Arches
    Before the rear arches can be tackled a large amount of filler needs to be removed from the rear quarters.
  34. #109
    Jul 2016
    Ireland
    187
    Re: Escort Mk1
    All the filler has masked another previous poor repair.
    The old replacement arch is removed.
  35. #110
    Jul 2016
    Ireland
    187
    Re: Escort Mk1
    The new arches offered up.
    Looks good.......except the previous repair has been bodged. There now isn't enough metal to attach the new arch too.
    The Magnum repair arch is only 4 inches wide - which isn't wide enough - Luckily the ex-press steel panels replacement is 6 inches wide.
  36. #111
    Aug 2006
    Christchurch, New Zealand
    463
    Re: Escort Mk1
    Wow that's a lot of filler!
    You're doing a grand job though and the thread is a great reference for others to use
  37. The Following User Says Thank You to Pikey15 For This Useful Post:
  38. #112
    Jul 2016
    Ireland
    187
    Re: Escort Mk1
    Rear Arches
    The Magnum Rear Arch repair panel isn't wide enough because of a previous repair to the rear arch.
    Luckily the Ex-pressed Steel arch is a few inches wider, these were ordered and arrived today.
  39. #113
    Jul 2016
    Ireland
    187
    Re: Escort Mk1
    What was really surprising was the difference in quality of the arches.
    The ex-pressed steel arch is thicker
    This is the Magnum Arch
    And the ex-pressed arch itself is more defined - possibly hand finished as opposed too just punched out of a press.
    The only down side is they are 3-4 times the price of the Magnum equivalent panel, but well worth it IMHO.
  40. #114
    Mar 2016
    North Wales
    58
    238
    15
    Re: Escort Mk1
    Magnum panels are awful, unfortunately I've only realised this after purchasing and fitting a few
  41. The Following User Says Thank You to waverunner For This Useful Post:
  42. #115
    Feb 2008
    London, England
    157
    Re: Escort Mk1
    Looking great you are doing a very thorough job. Well done so far
  43. The Following User Says Thank You to paul g For This Useful Post:
  44. #116
    Dec 2008
    Stockholm, Sweden
    35
    141
    I really appreciate all the detailed pictures and info regarding fitment, thanks for the effort of creating such a thread about your restoration. This will help me in the future for reference Keep on the good work!
    /David
  45. The Following User Says Thank You to Gyver For This Useful Post:
  46. #117
    Jul 2016
    Ireland
    187
    Re: Escort Mk1
    Quote Originally Posted by waverunner View Post
    The panels are OK - cost effective - but you must be prepared to work at fitting them!
  47. #118
    Jul 2016
    Ireland
    187
    Re: Escort Mk1
    Rear Stone Guard
    'Bolts' installed to attach rear stone guard -
    Hmmm - looks like an extra bolt?
  48. #119
    Jul 2016
    Ireland
    187
    Re: Escort Mk1
    Rear Arches and Tubs
    The rear arches need a fair amount of work - mainly because of a previous bad repair to both arches.
    Drivers Side
    Passenger Side
  49. #120
    Jul 2016
    Ireland
    187
    Re: Escort Mk1
    The rear wheel tubs are being replaced as well
    The replacement tubs need some work before installation
