Page 4 of 6 FirstFirst 1 2 3 4 5 6 LastLast
Results 121 to 160 of 210
Thread: Escort Mk1
  1. #121
    Jul 2016
    Ireland
    187
    Re: Escort Mk1
    Some of the small repairs on the replacement tubs -
  2. #122
    Jul 2016
    Ireland
    187
    Re: Escort Mk1
    The rear arches and tubs are removed
    These pictures highlight just how bad the previous repairs were
  3. #123
    Jul 2016
    Ireland
    187
    Re: Escort Mk1
  4. #124
    Jul 2016
    Ireland
    187
    Re: Escort Mk1
    Replacement tubs installed
  5. #125
    Jul 2016
    Ireland
    187
    Re: Escort Mk1
    Passenger Side Arch Fitted
  6. #126
    Sep 2014
    middlesbrough
    320
    Re: Escort Mk1
    perfection
  7. The Following User Says Thank You to andy-v For This Useful Post:
  8. #127
    Pit Crew Decade Plus User justinveal's Avatar
    Aug 2008
    south england
    1,659
    133
    Re: Escort Mk1
    Very nice not like my patch work quilt haha
  9. The Following User Says Thank You to justinveal For This Useful Post:
  10. #128
    Jul 2016
    Ireland
    187
    Re: Escort Mk1
    More work to the passenger side -
    Even using the wider ex-pressed steel arch - there is a gap which will need to be filled
    Tub repair
  11. #129
    Jul 2016
    Ireland
    187
    Re: Escort Mk1
    Tubs fitted
  12. #130
    Jul 2016
    Ireland
    187
    Re: Escort Mk1
    Spare wheel trough and Fuel Tank trough
    Spare wheel retaining strap bracket - mounted to the boot floor
  13. #131
    Jul 2016
    Ireland
    187
    Re: Escort Mk1
    Quote Originally Posted by justinveal View Post
    I've just removed a patch work !!
  14. #132
    Aug 2008
    south england
    1,659
    133
    Re: Escort Mk1
    Wow that is some intresting patch work lol, i have just been cutting out my drivers side floor pan, all 5 layers of it!!!!
  15. The Following User Says Thank You to justinveal For This Useful Post:
  16. #133
    Jul 2016
    Ireland
    187
    Re: Escort Mk1
    Dashboard
    The replacement six dial dash is installed
  17. #134
    Jul 2016
    Ireland
    187
    Re: Escort Mk1
    Bulkhead Corners
    The finish on the bulkhead corners wasn't the greatest
    So a small skim of filler is applied
  18. #135
    Jul 2016
    Ireland
    187
    Re: Escort Mk1
  19. #136
    Jul 2016
    Ireland
    187
    Re: Escort Mk1
    Rear Scuttle Panel
    As with most of this car - has been previously repaired badly
    The entire rear bulkhead, parcel shelf and rear scuttle are going to be replaced with a cut from the donor car
    Unfortunately it's not going to be as easy as just weld in the replacement panel - as the inner scuttle has some rust
  20. #137
    Jul 2016
    Ireland
    187
    Re: Escort Mk1
    So the repair will involve the best parts of both panels and a new fabricated inner scuttle panel.
    The old scuttle panel is removed
    Exposing the inner scuttle
    Another pile of scrap!!
  21. #138
    Jul 2016
    Ireland
    187
    Re: Escort Mk1
    Using the replacement scuttle and a fabricated piece the inner scuttle is replaced
  22. #139
    Jul 2016
    Ireland
    187
    Re: Escort Mk1
    Fabricated Inner Scuttle Finished
  23. #140
    Sep 2014
    middlesbrough
    320
    Re: Escort Mk1
    top job looks great.
  24. The Following User Says Thank You to andy-v For This Useful Post:
  25. #141
    Jul 2016
    Ireland
    187
    Re: Escort Mk1
    Rear Parcel Shelf and firewall
    Trimmed off the rusty metal from the donor shelf which left the exposed inner section, treated the surface with rust converter and left to sit for 24 hours, and finally sprayed with weld thru primer ready for fitting.
  26. #142
    Jul 2016
    Ireland
    187
    Re: Escort Mk1
    Another piece of the jigsaw complete 78 plug welds and 6 stitch welds later the parcel shelf fitted like a glove.
  27. #143
    Jul 2016
    Ireland
    187
    Re: Escort Mk1
    Next on the hit list to be repaired is the outer scuttle.
    then rust treated and painted diamond white underneath.
    Trimmed up the outer scuttle and painted with rust converter,,
  28. #144
    Jul 2016
    Ireland
    187
    Re: Escort Mk1
    The rear scuttle turning black - this is a sign of the rust converter doing its job,,
    Fuel Filler Neck
    Yet another repair bodge!
  29. #145
    Jul 2016
    Ireland
    187
    Re: Escort Mk1
  30. #146
    Jul 2016
    Ireland
    187
    Re: Escort Mk1
    Trial Fitting of the fuel tank
    All mounting holes actually line up even after all the shell realignment.
  31. #147
    Sep 2014
    middlesbrough
    320
    Re: Escort Mk1
    looking great.
  32. The Following User Says Thank You to andy-v For This Useful Post:
  33. #148
    Jan 2011
    Sarf Rugeley
    584
    32
    Re: Escort Mk1
    Great thread. Thanks for taking the time to put this thread together.
    How did you go about making the jig?
  34. #149
    Jul 2016
    Ireland
    187
    Re: Escort Mk1
    Door Repairs
    Two new door skins from NHC Panels
  35. #150
    Jul 2016
    Ireland
    187
    Re: Escort Mk1
    Removing the old skins exposed over 40 years of water damage and rust!!
    The strengthening strut brace across the door also showed signs of corrosion
    So has been replaced.
  36. #151
    Jul 2016
    Ireland
    187
    Re: Escort Mk1
    One of the doors only needed a patch across the bottom
    The other door required the entire bottom to be replaced - a section was cut in order to reproduce the profile.
    To be welded in the door
  37. #152
    Jul 2016
    Ireland
    187
    Re: Escort Mk1
  38. #153
    Mar 2014
    London
    110
    Re: Escort Mk1
    Nice work... A small step closer
  39. #154
    2,659
    268
    Re: Escort Mk1
    Very nice.
    I hope its not too late though, but can I just give a bit of advice.
    Those repair sections on the doors should really have some drain slots in them...
  40. The Following User Says Thank You to rallyrob For This Useful Post:
  41. #155
    Jul 2016
    Ireland
    187
    Re: Escort Mk1
    The drivers side frame repaired and then rust treated
    Then two pack primer and coloured white inside and ready for the final fit of the skins,
  42. #156
    Jul 2016
    Ireland
    187
    Re: Escort Mk1
    Along with the door sills
    Drain Holes added -
  43. #157
    Jul 2016
    Ireland
    187
    Re: Escort Mk1
    With the repairs to the bottom of the inner part of the door.
    And door drains drilled
  44. #158
    Jul 2016
    Ireland
    187
    Re: Escort Mk1
    The inner part of the door and the new door skin are prepared in two pack primer and coloured white inside
    The new door skins are fitted.
  45. #159
    Jul 2016
    Ireland
    187
    Re: Escort Mk1
    The new door skin is tapped into shape around the inner part of the original door shell.
    And blended in with the original door
  46. #160
    Jul 2016
    Ireland
    187
    Re: Escort Mk1
    Next the seat belt anchor plates are welded to the floor pan and will eventually be covered by the sills.
    And then primed
