Page 5 of 6 FirstFirst 1 2 3 4 5 6 LastLast
Results 161 to 200 of 210
Thread: Escort Mk1
  1. #161
    Jul 2016
    Ireland
    187
    Re: Escort Mk1
    Next the seat belt anchor plates are welded to the floor pan and will eventually be covered by the sills.
    And then primed
  2. #162
    May 2010
    london
    1,139
    Re: Escort Mk1
    coming on strong...like the door refurb...is there no welding on the skin...did you use any bonding agent..or is it just a crush fit....grat skills ...cheers mark
  3. The Following User Says Thank You to madragon199 For This Useful Post:
  4. #163
    Jul 2016
    Ireland
    187
    Re: Escort Mk1
    Quote Originally Posted by madragon199 View Post
    Firstly the door skin had holes drilled approx every 3 inches along its edge, so that it could be plug welded, then primed and painted inside.
    I
    I've highlighted the holes in this picture.
    Then the door skin was offered up to the door shell and only the top corner tacked, this allows the skin position to adjusted to ensure the best fit. It was then crush fitted and finally welded using the holes already drilled, finally after paint I'll use some seam sealer to prevent any moisture ingress.
    Fairly time consuming but the fit is fantastic.
  5. The Following User Says Thank You to Perry Oaks For This Useful Post:
  6. #164
    Jul 2016
    Ireland
    187
    Re: Escort Mk1
    Fitting the Doors and door shuts!
    Again due to previous bad repairs the striker plates need sorting.
  7. #165
    Jul 2016
    Ireland
    187
    Re: Escort Mk1
  8. #166
    Jul 2016
    Ireland
    187
    Re: Escort Mk1
    Doors Fitted
  9. #167
    Jul 2016
    Ireland
    187
    Re: Escort Mk1
    Both Sills replaced
  10. #168
    Jul 2016
    Ireland
    187
    Re: Escort Mk1
    Anti-tramp bars Fitted
    Brackets welded to the axle
  11. #169
    Jul 2016
    Ireland
    187
    Re: Escort Mk1
    Painting the bits you can't see!!
    Under the heater bubble
    Then the heater bubble welded on
  12. #170
    Jul 2016
    Ireland
    187
    Re: Escort Mk1
    Under the scuttle panel
    The the scuttle panel welded in place
  13. #171
    Jul 2016
    Ireland
    187
    Re: Escort Mk1
    Seam Sealed
  14. #172
    Jul 2016
    Ireland
    187
    Re: Escort Mk1
  15. #173
    Jul 2016
    Ireland
    187
    Re: Escort Mk1
    Inner Wings and inside of Wings Painted
  16. #174
    Jul 2016
    Ireland
    187
    Re: Escort Mk1
    Inside of the door shell also painted
    Wings finally welded in place
  17. #175
    Jul 2016
    Ireland
    187
    Re: Escort Mk1
    Front Struts converted to Coil Overs
  18. #176
    Jul 2016
    Ireland
    187
    Re: Escort Mk1
    Test fitting the engine and gearbox
    Fitting a Focus ST170 engine
    Some custom fit engine mounts are made.
  19. #177
    Jul 2016
    Ireland
    187
    Re: Escort Mk1
    Mated with a type 9 gearbox
    As the gearbox is longer that the standard escort gearbox - the gear lever hole needs to be moved.
    And needs the existing gearbox mounts to be moved
  20. #178
    Jul 2016
    Ireland
    187
    Re: Escort Mk1
  21. #179
    Jul 2016
    Ireland
    187
    Re: Escort Mk1
    Test Fit the Exhaust
  22. #180
    Jul 2016
    Ireland
    187
    Re: Escort Mk1
    Rear Valance needs some adjustment
  23. #181
    Jul 2016
    Ireland
    187
    Re: Escort Mk1
    The car was then removed from the restoration Jig and moved onto a roll over Jig for the last few bits and pieces before paint
  24. #182
    Jul 2016
    Ireland
    187
    Re: Escort Mk1
    Seat Braces fitted
  25. #183
    Jul 2016
    Ireland
    187
    Re: Escort Mk1
    Clips to hold the rear bench seat in place
  26. #184
    Jul 2016
    Ireland
    187
    Re: Escort Mk1
    Holes drilled for front and rear lights
  27. #185
    Jul 2016
    Ireland
    187
    Re: Escort Mk1
    Parcel Shelf Brackets
  28. #186
    Jul 2016
    Ireland
    187
    Re: Escort Mk1
    Fitting the wheels
    The rear leaf springs have had the camber slightly to reduced to lower the car
  29. #187
    Jul 2016
    Ireland
    187
    Re: Escort Mk1
    LSD!!
  30. #188
    Jul 2016
    Ireland
    187
    Re: Escort Mk1
    Rear Axel
  31. #189
    Jul 2016
    Ireland
    187
    Re: Escort Mk1
    The engine and gearbox are then removed and 'old' suspension fitted.
    Off to Paint!
  32. #190
    Aug 2006
    Christchurch, New Zealand
    463
    Re: Escort Mk1
    Looking good mate
  33. The Following User Says Thank You to Pikey15 For This Useful Post:
  34. #191
    Jan 2012
    Aberdeenshire
    417
    Re: Escort Mk1
    Great job, will be looking forward to seeing her back so you can rebuild her
  35. The Following User Says Thank You to donnie For This Useful Post:
  36. #192
    Mechanic DANGERDAVE80's Avatar
    Jul 2008
    Edinburgh, United Kingdom, United Kingdom
    806
    Re: Escort Mk1
    Wow, what an amazing build! Your fab skills are spot on mate, look forward to following the build of this one
  37. The Following User Says Thank You to DANGERDAVE80 For This Useful Post:
  38. #193
    Jul 2016
    Ireland
    187
    Re: Escort Mk1
    Paint Prep !
  39. #194
    Jul 2016
    Ireland
    187
    Re: Escort Mk1
  40. #195
    Jul 2016
    Ireland
    187
    Re: Escort Mk1
  41. #196
    Jul 2016
    Ireland
    187
    Re: Escort Mk1
    Whilst the shell is away the engine is stripped down for reconditioning
  42. #197
    Jul 2016
    Ireland
    187
    Re: Escort Mk1
    Sourced a new impeller from IK engineering, for the water pump, so its turns in the opposite direction.
    Because the waterpump will turn in opposite direction, normally it uses a smooth fan belt pulley - but as its using the opposite side of the fan belt I need to use a ribbed pulley.
    Ordered from a lad on this forum.
  43. #198
    Jul 2011
    London
    Re: Escort Mk1
    Great work what throttle bodies you using and are you using the vvt on the st170
  44. The Following User Says Thank You to dannybhoy For This Useful Post:
  45. #199
    Jul 2016
    Ireland
    187
    Re: Escort Mk1
    Quote Originally Posted by dannybhoy View Post
    I've gone for an OMEX fuel injection setup with the OMEX 600 ECU to control the VVT.
  46. #200
    Mechanic stevieel's Avatar
    Dec 2003
    Teesside
    674
    24
    Re: Escort Mk1
    Fantastic piece of work there, looks awesome keep up the good work
    Will she ever see daylight.............:-(
  47. The Following User Says Thank You to stevieel For This Useful Post:
