Results 1 to 14 of 14
Thread: Lsd noisy can you give me some info
    Mechanic cookster's Avatar
    Nov 2007
    London, United Kingdom, United Kingdom
    641
    21
    Hi basically just bought a brand new lsd set up for fast road it's a 3j driveline Salisbury been set up for fast road. I have just put it in and it's fine at coasting but when you go slow or go round a corner it's well noisy. I'm thinking it has to bed in and the oil to get round is what the noise is that's what I'm hoping anyway
    Spanner Monkey ugg10's Avatar
    May 2014
    South Coast
    175
    30
    Re: Lsd noisy can you give me some info
    As far as I am aware the 3j is a plated diff and they all do this cornering at low speed, if you want quiet then the quaife atb is the one to go for but there are down sides in other respects.
    Nov 2007
    641
    21
    Yea it's the plated one I'm sure once it beds in and oil get round should be a bit quieter cause it's at low speed as ya just pull of as well
    9,204
    Does it clack loudly on overrun ?
    Nov 2007
    641
    21
    No nothing on overun only went round the corner and heard it and bought it back just in case I did any damage. Was a bit low on oil as well cause I put a litre in and thought that be okay but then it took another 300ml before it came out of the fill up plug and that was on a level surface
    May 2014
    South Coast
    175
    30
    Silly question, you did used the right oil for the lsd, they do not use the same oil as an open diff.
    Nov 2007
    641
    21
    Yea right oil b373 castrol lsd what I got told to use with it
    Jul 2010
    South Wales
    4,689
    221
    Quote Originally Posted by cookster View Post
    Plated diffs are normally noisey but it depends on how the diff is set up how noisey. Do around 500/1000miles and drop the oil. If your running an atlas take the back cover off and really clean out the diff housing. It should bed in and be a bit quieter after that then. Also castrol b373 is the proper oil for the job.
    Nov 2008
    Bored
    1,380
    I had one they are very noisey Even when bedded in I took it off in the end
    Aug 2013
    doncaster
    i have one in my atlas and its quiet from cold then louder when warms up, loud clunks at slow cornering speed, I rang 3j and they told me this was normal for the diff
    Jun 2006
    SE London
    16
    I had this with my Tran-x plated diff, I did some figure 8s for 20mins and then changed the oil and added some redline friction modifier, been quiet since and locks up a treat.
    Nov 2007
    641
    21
    Thanks for all the info guys to be honest it's a lot more quiet now I drove it 25 miles and it's a lot better was just worried to start with thanks again knocking on the front coil overs now never ending ah
    Jun 2006
    kilkenny, ireland
    519
    All plate diffs make some noise, at least my tran-x did, it was really noticeable when going slow or parking. Its part of the escort experience!
    Spanner Monkey Kmp's Avatar
    Feb 2009
    Burnham on sea
    390
    Is your lsd better now? Just googled this problem because I have the same issue, I can hear the car the other side of the industrial estate as the grinding noise is that loud. Sounds terrible, again checked everything and even changed the wheel bearings as a matter of course. Someone has said that there isn’t any oil getting in between the plates, from new they have wd40 or similar on them, so when you fit the diff is takes a while for the proper oil to get between the plates. That’s what we’re hoping because is sounds horrendous, like a chalkboard scratch combined with a metal on metal noise.
    Kris
