Results 1 to 8 of 8
Thread: Ignition
    Aug 2014
    300
    31
    Ignition
    What ignition set up are you using on your N/A engines.
    i also want to run rev limiter / launch control so interested in options
    Aug 2014
    300
    31
    Re: Ignition
    Anyone?
    Spanner Monkey Mkdu's Avatar
    Oct 2009
    417
    14
    Re: Ignition
    I think most of N/A are on ECU and throttle bodies
    Mine is on typhoon2 ECU, AT throttle direct to head
    Aug 2014
    300
    31
    Re: Ignition
    Quote Originally Posted by Mkdu View Post
    I'm on 48s for now so I'm looking for ideas on a simple electronic ignition set up I can add rev limiter. throttle bodies might be a later upgrade
    4,889
    Re: Ignition
    Lumenition Performance Ignition system plus a Lumenition Rev Limiter if you are running a distributor ignition.
    Aug 2014
    300
    31
    Re: Ignition
    Will that run bosh electronic dizzy
    Oct 2009
    417
    14
    Re: Ignition
    123ignition is great but I don't think they do one for pinto ?
    I used one for Xflow, awesome, customs curves and rev limiter all inside a standard dizzy
    4,889
    Re: Ignition
    Quote Originally Posted by mark2cossie View Post
    No.
