Sierra Cosworth 2wd throttle position sensor issues/ settings
I've been on the forums etc to try to get info on the different voltages etc so I understand all this, now when I'm testing the voltage I unplug the connector on the ecu then locate the correct connectors to attach the multimeter to, then operate the throttle, I'm getting absolutely nothing unless I hold the positive with my finger then I get 0.5 volts but this does not change at all, if u remove my finger from the lead it goes to zero, I've checked the wires from the connector on the tps to the plug on the ecu and they are ok, I'm now at a loss as to why I'm getting nothing voltage wise at the plug, is it me and my connections onto the ecu plug or is my tps completely knackered, any help would be much appreciated
How u gonna get voltage if u unplug the Ecu multi plug ?
Sent from my Bavs iPhone
Re: Sierra Cosworth 2wd throttle position sensor issues/ settings
Correct having a blonde moment, sorted it now thanks🙈
