Results 1 to 10 of 10
Thread: track rod ends???
    Racer Decade Plus User x-pack's Avatar
    Mar 2006
    Leyland, Lancs
    2,102
    169
    track rod ends???
    I tried to get some track rod ends for my Mk2 escort but couldn't seem to get the right ones from my local motor factors.
    I tried ones from Mk1 and 2 escorts and ones from a capri. I think the Escort ones were the same as for a capri and they screwed onto my rack ok but were too big for the hub arm. The Mk1 Escort TRE's fitted the arm but not the rack ... ahhh!
    I have what I think is a quick rack .. but i'm not 100% sure. My suspension is WC Bilsteins which I presume would be similar to a Capri's front set up - 2.8i disks and hubs etc.
    Please help. I could drill the arms to fit the Mk2 Escort TRE's .. don't want to though
    I'm going to pull your head off because i don't like your head!
    I support TS Decade Plus User
    4,317
    18
    Re: track rod ends???
    You probably need Green TRE from a Mk2 RS; they have metric rack thread and fit the bolt-on steering arms on the struts.
    Mar 2006
    Leyland, Lancs
    2,102
    169
    I thought it could be something like that. Cheers
    Does anyone know if the the green TRE's are the same size as the standard MK2 Escort fitting on the ball joint end - where they fit into the steering arm?
    4,317
    18
    Green TRE's have Mk2 thread (metric) on the rackside and have Mk1 type UNF tapers for the steering arm to fit in.
    Normal TRE's are black but as said you need the special green ones.
    Mar 2006
    Leyland, Lancs
    2,102
    169
    Them's the ones!
    Cheers. I bet they're bloody expensive as well!
    TURBOSPORT SPONSOR Decade Plus User
    Turbosport Sponsor
    GP4's Avatar
    Sep 2003
    Carmarthenshire
    1,773
    Quote Originally Posted by x-pack View Post
    Them's the ones!
    You can get them from any decent motor factors mate...brands such as First Line or Quinton Hazell make the same fitment part as the genuine Ford green item, and are normally around 7 or 8 each instead of the 20+ you'll pay for the originals. Just make sure you ask for/receive Mk.2 RS2000/RS1800/Mexico as no other tre will suit your needs.
    HTH's...
    Mar 2006
    Leyland, Lancs
    2,102
    169
    Excellent
    I have seen them TRE's from Ian Harwood's etc for 25 or somethin ridiculous. Are these the 'green' TRE's? Forgive me for what might be a stupid question, but why are they called 'green'?
    Baz
    4,317
    18
    Because the colour of the TRE's is ... wait for it .... GREEN !!
    Mar 2006
    Leyland, Lancs
    2,102
    169
    I'll just get my coat then...
    Racer Decade Plus User Mr_Hoarder's Avatar
    Sep 2001
    Essex
    2,811
    Quinton Hazell QR4118s (2 off) is what you need
    www.RWD-Escort.co.uk
    I was a TS overhauler
Similar Threads
  1. Green track rod ends
    By Cosnada in forum General Car Banter
    Last Post: 09-01-2006, 09:55
  2. Track rod ends
    By Bart2207 in forum The Technical Section
    Last Post: 22-02-2005, 10:17
  3. Green Track Rod Ends
    By Willid1 in forum The Technical Section
    Last Post: 14-11-2004, 02:27
  4. Track rod ends
    By Paul_G in forum The Technical Section
    Last Post: 25-03-2004, 23:14
  5. green track rod ends
    By bobb1 in forum The Technical Section
    Last Post: 17-02-2004, 13:03
