Results 1 to 11 of 11
Thread: Need Pictures of Small rear side water pipe and other Water Pipe pictures...
    May 2016
    Germany
    288
    63
    Hi, I found some Diagrams for Water flow management with and without heater, but I never saw Pictures from solutions...I guess there is not enough space with Body mounted engine mountings on the rear side of the XE engine .(Escort MKII)
    How can I fix it (90 degree pipe, other ways...)
    How do you fix it with the water pipe at the waterpump? Self made T or are there any other solutions.
    Do I need to use a separate Waterbottle into the cooling system?
    Thanks for your help...and for pictures.
    Dennis
    # Germany #
    Jun 2012
    ireland
    1,158
    Re: Need Pictures of Small rear side water pipe and other Water Pipe pictures...
    hi Dennis, i made this solution, works perfectly so far
    May 2016
    Germany
    288
    63
    I found this picture too! Nice solution. Can you take a picture from the engine fitted into your car? The area of interest is under the inlet manifold... and the clearance with this solution to the bulkhead!Have you glued it or cut a thread into the head... Many many thanks!!
    Jun 2012
    ireland
    1,158
    sure, here is the engine, but il take a photo of the back later on for you, in the fitting i put a standard plumbing copper pipe in with a bead on the end so a heater hose goes on perfectly.
    first i tried to cut a thread, but of course knowing the luck, the fitting finishes upside down!
    so, i turned the threads down on the fitting in the lathe so it was a tight interference fit, put the fitting in the freezer, heated up the head and pressed it in, its not coming out!
    the JB weld was just for good measure, but totally not necessary its very tight.
    il take a photo of the back of it tonight for you
  5. The Following User Says Thank You to onecamohv For This Useful Post:
  6. #5
    May 2016
    Germany
    288
    63
    Still waiting for the picture...
  7. #6
    Jun 2012
    ireland
    1,158
    ah totally forgot about this sorry, will take it as soon as i get home this afternoon
  8. #7
    Jun 2012
    ireland
    1,158
    im actually revisiting this at the weekend, and going to sort out a heater for the winter. i had put it off during the summer, but now my feet are freezing
  9. #8
    Jun 2012
    ireland
    1,158
    It was very hard to see but I hope this helps?
  10. #9
    Jun 2012
    ireland
    1,158
  11. #10
    May 2016
    Germany
    288
    63
    Great view! Thanks for gettig the feet cold for me!!!
  12. #11
    Jun 2012
    ireland
    1,158
    Nichts zu danken
Tags for this Thread
