Engine Standard apart from the mildest cam Kent does and a tickled head.
Cossie Management fitted with Injection inlet Plenum.
131.8![]()
Is this dyno accurate though Clint ??![]()
www.RWD-Escort.co.uk
I was a TS overhauler
thats good for an engine with the mods listedtop job
I take it thats flywheel figure?
only asking cos i want to compair it to my EFi pinto RR figure but that was at the rear wheels .
That looks pretty good actually - pretty much what I'm planning so that gives me a good idea of what to expect.
stick some twin carbs on it and it will be even better![]()
Popup: how does Esme go compared to others you've taken out![]()
BMW E93 330d & VW Caddy SDi
thing thing to take in to consideration is esme has an autobox, and clint has very wisely built an engine which lugs well from low revs, exactly what you need with a street driven auto which hasn't got a modded box and high stall speed converter
Very flat torque curve so I would expect that it goes very well. Hard to judge with the auto box I suppose.
she pulls very well through the gears, plenty quick enough off the line to suprise people in hot hatches, goes well on kickdown as well.
goes well enough to earn you hard stares from the owner anyway.![]()
