Page 2 of 6 FirstFirst 1 2 3 4 5 6 LastLast
Results 41 to 80 of 233
Thread: Thread thread
  1. #41
    Nov 2003
    Wirral UK
    6,740
    257
    Re: Thread thread
    Just a couple more :
    MK1 RS roller top strut mounts - 5/16 UNF (24tpi)
    MK1 rack-to-crossmember bolts - 5/16 UNC (18tpi)
    More to come as I find them.
    http://escort.accelerator.org
  2. #42
    Brum Town
    1,822
    26
    Re: Thread thread
    in need of the thread on the bottom of a mk2 petrol tank. the one thats on the end of the petrol pipe........
  3. #43
    Spam Man
    Feb 2008
    Telford
    169
    Re: Thread thread
    Quote Originally Posted by para144 View Post
    After seaching the forums for bolt sizes on my Escort, I thought it might be a good idea to put all the ones I found in one place so people can add to & use the info.
    ENGINE & GEARBOX
    Crossflow engine bolts (in block): 5/16 UNC.
    Crossflow 1300-1600 flywheel bolts: 3/8 UNF.
    Pinto spark plug thread: M18x1.5.
    Pinto oil pressure switch: 1/4 NPT (pipe thread).
    Pinto alloy sump to engine bolts: M6x18
    Pinto alloy sump plug: M12x20
    RS alloy bellhousing bolts: M10x1.5 (30mm long).
    AXLE & PROP
    Propshaft to Atlas/English axle bolts: M10x1.0mm pitch.
    Drum brakes to english axle Mk1: 7/16 UNF.
    Drum brakes to english axle Mk2: M12x1.5.
    SUSPENSION & BRAKES ETC
    Caliper to strut bolt (2.8i strut): 7/16 UNF.
    Disc to hun bolts 2.8/RS hubs: 3/8 UNC.
    Mk1 Escort wheel studs: 7/16 UNF.
    Mk2 Escort wheel studs: M12x1.5.
    Group 4 wheel studs: 1/2 UNF.
    Bilstein competition/Escort RS front insert bottom thread: M10x1.0mm.
    BODY/MISC
    Escort seatbelt mounts: 7/16 UNF
    if some one can provide lengthes i can sort alot of those bolts
    already have alot of the m series ones
  4. #44
    Brum Town
    1,822
    26
    Re: Thread thread
    righty.......
    i need to know, the bottom of the petrol tank, mk2 escort, is that ''Large inner tank outlet 3/4 BSP on Mk1 and most probably Mk2''?
    then i need a water temperature sensor thread for crossflow mk2 escort
    thanyou muchly
  5. #45
    Dave's Avatar
    Oct 2003
    Cheshire
    19,588
    141
    Re: Thread thread
    I thought the tank fitting was 3/4 bsp, but Matt and his Dad reckoned it wasn't quite. The pitch was very slightly different.
  6. #46
    Brum Town
    1,822
    26
    Re: Thread thread
    i'll take the old one to a plumbing shop the weekend, even though i know they won't have what i want
  7. #47
    Racer 4drmatt's Avatar
    Jun 2007
    Bedford
    2,079
    69
    Re: Thread thread
    does anyone know what thread a capri laser wheel nut is???
  8. #48
    Pit Crew Decade Plus User merp0's Avatar
    Jun 2007
    Chester, Cheshire, United Kingdom
    1,284
    100
    Re: Thread thread
    M12, aren't they?
  9. The Following User Says Thank You to merp0 For This Useful Post:
  10. #49
    Spanner Monkey olly22n's Avatar
    Sep 2006
    Stamford, Lincs
    334
    Re: Thread thread
    Does anyon know the sizes of the bolts to a rs2000 flywheel, the ones that hold the clutch on??
    thanks
    Olly
  11. #50
    Re: Thread thread
    How about a the nut for the top of a bilstein strut. The one that holds the top mount on
  12. #51
    Dave's Avatar
    Oct 2003
    Cheshire
    19,588
    141
    Re: Thread thread
    I'm pretty sure they are UNF. Ask Ratters if he remembers, we had this conversation once.
  13. #52
    Re: Thread thread
    Just been to my local nut and bolt man who tells me they are m12 with a 1.25 pitch (fine) he tested one with a bolt. He had none in stock
    Just looked on e-bay and size seems to be wheel nuts but there are 1 or 2 normal ones so maybe it is right
  14. #53
    Dan's Avatar
    Aug 2006
    north london
    4,378
    115
    Re: Thread thread
    just thought id add
    xflow oil pressure take-off:
    1/8 NPT for 681 blocks
    1/4 NPT for 691 and 711m
  15. #54
    Re: Thread thread
    The high priced ebay ones turned up and fitted m12 with a 1.25 pitch fit my AVO billie replacements and the original capri nuts fitted these aswell.
  16. #55
    Sep 2006
    Stamford, Lincs
    334
    Re: Thread thread
    anyone know the thread for the seat bolts on a mk2 escort??
  17. #56
    Moderator+ Decade Plus User
    dangerousdave's Avatar
    Oct 2002
    London
    15,132
    65
    Re: Thread thread
    More than likely to be a plain m6 or m8 bolt....but i dont think i have ever used the standard captive nuts as im sure they all had bolts rusted in them so i chopped them off!
  18. #57
    Sep 2006
    Stamford, Lincs
    334
    Re: Thread thread
    thats what i thought, but they're not!
    Would rather keep them as they're orginal so any other ideas what they could be??
  19. #58
    Nov 2003
    Wirral UK
    6,740
    257
    Re: Thread thread
    They will be metric.
    It might just be corrosion preventing the bolt going through them, have you tried running a tap down the thread to clean it up?
  20. #59
    Sep 2006
    Stamford, Lincs
    334
    Re: Thread thread
    good point, the car has been sprayed so prob clogged the threads up!
  21. #60
    Oct 2002
    London
    15,132
    65
    Re: Thread thread
    That said the rear exhaust hanger bracket bolts are imperial
  22. #61
    Jun 2004
    Bristol
    1,494
    18
    Re: Thread thread
    Quote Originally Posted by olly22n View Post
    They take a 7/16" spanner which makes them 1/4" UNC I think
  23. #62
    Re: Thread thread
    Quote Originally Posted by seventynine View Post
    crossmember to body - 3/8 unf
    Great "thread" just answered my question straight away
  24. #63
    Jun 2007
    Whitley Bay
    3,437
    81
    Re: Thread thread
    Steering rack nuts to lock track rod ends M14
    Screaming 1300 mexico rep
  25. #64
    Dave's Avatar
    Oct 2003
    Cheshire
    19,588
    141
    Re: Thread thread
    Quote Originally Posted by 4drmatt View Post
    M12x1.5mm pitch
    Same as Type 9 bellhousing bolts
  26. #65
    Nov 2003
    Wirral UK
    6,740
    257
    Re: Thread thread
    MK1 Axle u-bolts
    7/16 UNF (20tpi)
  27. #66
    Pit Crew Decade Plus User para144's Avatar
    Jan 2006
    South Wales
    1,075
    75
    Re: Thread thread
    Did a bit of an update with info from this thread:
    ENGINE
    Crossflow
    Engine bolts (in block): 5/16 UNC.
    Oil pressure take-off: 1/8 NPT for 681 blocks & 1/4 NPT for 691 and 711m.
    Thermostat Housing: 5/16 UNC 25mm long
    Inlet Manifold: 5/16 UNC 25mm long
    Exhaust Manifold: 5/16 UNC 25mm long
    Oil Pump: 5/16 UNC 25mm long
    Rear Crank Cover: 5/16 UNC 25mm long.
    Water pump x2: 1/4 UNC
    Water Pump x1 (alternator bracket one): 5/16 UNC 25mm long
    Sump bolts:
    Oil Breather Box:
    Distributor to block: all 1/2" long
    Front Timing Cover: all are 20mm apart from 1 which is 43mm long
    Pinto
    Pinto alloy sump plug: M12x20.
    Pinto block drain: 3/8 NPT
    Gearbox & Bell housing
    RS alloy bellhousing to engine bolts: M10x1.5 (30mm long).
    Bellhousing to type 9 gearbox: M12 x 1.5 FINE
    AXLE & PROP
    Mk1 Axle U bolts: 7/16 UNF (20tpi)
    SUSPENSION, STEERING & BRAKES ETC
    Disc to hub bolts 2.8/RS hubs: 3/8 UNC.
    Brake pipe unions metric: M10X1
    Brake pipe unions imperial: 3/8 UNF
    Bilstein competition/Escort RS type front insert bottom thread: M10x1.0mm.
    Leaf spring (front): 7/16 UNC
    Mk2 Steering rack track rod end lock nuts: M14
    MK1 rack-to-crossmember bolts: 5/16 UNC (18tpi)
    Capri wheel nuts: M12x1.5mm
    BODY/MISC
    Cross member to body: 3/8 UNF
    Mk2 Escort - most bolts are M8 (ie bonnet, boot, hinges, etc)
  28. #67
    Sep 2008
    southampton
    Re: Thread thread
    i had a problem a few weeks back finding long enough bolts to mount my lotus twink onto a clarke engine stand i think they were 3\8th unc but they needed to be at least 4 inches long after many days of running around with a bolt in my hand lawsons fastenings and fixings in southampton came up with the goods and they can supply any bolt size or length off the shelf if not they can get it within 24 hours they sorted me right out.
  29. #68
    Spanner Monkey Phil01825's Avatar
    Dec 2005
    East Sussex
    335
    Re: Thread thread
    Happy New Year everyone. What's the thread on the TCA?
  30. #69
    Dave's Avatar
    Oct 2003
    Cheshire
    19,588
    141
    Re: Thread thread
    IIRC a 9/16 spanner fits on it, and it is a fine thread, so I would say 3/8 UNF
  31. #70
    Dave's Avatar
    Oct 2003
    Cheshire
    19,588
    141
    Re: Thread thread
    Quote Originally Posted by dangerousdave View Post
    Blue nylocks = metric,
    white = imperial
    When you first said that I thought "Oh, I never knew that"
    However, it's not true, cos I have some imperial nylocs in blue and some in white.
  32. #71
    Oct 2002
    London
    15,132
    65
    Re: Thread thread
    all the ones i have ever had or bought have followed those rules
  33. #72
    Feb 2007
    Norway
    942
    58
    Re: Thread thread
    Zetec oil filter is 3/4"-16 UNF - HTH
    67 TVR VIXEN V8
  34. #73
    Dec 2005
    East Sussex
    335
    Re: Thread thread
    Quote Originally Posted by Dave View Post
    Cheers, I'll give them a try.
  35. #74
    Re: Thread thread
    I came to that rule and it has always held good when searching through the escort bolts bucket I shall be that bit more carefull in future
  36. #75
    Dec 2005
    East Sussex
    335
    Re: Thread thread
    TCA Ball Joint nut is a 7/16 UNF.
  37. #76
    Dec 2007
    Dubai
    1,678
    29
    Re: Thread thread
    Any idea what the top nut on the D shaped short Billie inserts. Looks like it might be 16mm, but what thread?
    www.gulfpetrolheads.com
  38. #77
    Mechanic zetecfourdoor's Avatar
    Feb 2008
    bonnie scotland
    846
    20
    Re: Thread thread
    does anybody know the thread size of the stud that the rear shock mounts to on the spring plate?
    cheers
    Four doors do it sideways too
  39. #78
    Part of the furniture Decade Plus User Ratters's Avatar
    Mar 2004
    Bristol
    8,648
    75
    Re: Thread thread
    mk1 rear shackle nuts anyone know?
    they take 1/2" spanner & look quite course
  40. #79
    Mar 2004
    Bristol
    8,648
    75
    Re: Thread thread
  41. #80
    Dave's Avatar
    Oct 2003
    Cheshire
    19,588
    141
    Re: Thread thread
    Shackle thread is 5/16ths UNC
Similar Threads
  1. Pinto Spart Plug Thread / Lambda Thread
    By Dalek in forum The Technical Section
    Last Post: 24-05-2005, 19:04
Tags for this Thread
