Page 6 of 6 FirstFirst 1 2 3 4 5 6
Results 201 to 233 of 233
Thread: Thread thread
  1. #201
    Spanner Monkey Tony B.'s Avatar
    Mar 2007
    Nr Chichester, West Sussex
    74
    331
    23
    Re: Thread thread
    Hi, are the inner track control arm to crossmember bolts different on a Mk1 & Mk2 ? On after market arms there seems to be a lot of slack in the bush.
  2. #202
    Mechanic Bigfish's Avatar
    Dec 2009
    Beds
    891
    Re: Thread thread
    Quote Originally Posted by Tony B. View Post
    mk1 and mk2 are the same. its probably because the aftermarket bushes have been made to metric and not imperial
    1974 MK1 Escort - Work in Progress
  3. #203
    Oct 2008
    whitley bay
    2,436
    89
    Re: Thread thread
    Does anyone know the thread of the studded part coming out of an rs2000 engine mount ?
    Hexham and District Motorclub
  4. #204
    Dec 2009
    Beds
    891
    Should be M10
  5. The Following 2 Users Say Thank You to Bigfish For This Useful Post:
  6. #205
    Oct 2008
    whitley bay
    2,436
    89
    Re: Thread thread
    Thank you
  7. #206
    Spanner Monkey fullathepipe's Avatar
    Sep 2010
    Ballymena northern ireland
    334
    20
    Thread thread
    Already posted this in discussion before noticing this part. Cross flow inlet bolts can anyone tell me the thread where you bolt the carb on. I know it's not m8
  8. #207
    Dave's Avatar
    Oct 2003
    Cheshire
    19,588
    141
    Re: Thread thread
    It will be UNC I guess, whichever one a 1/2" spanner fits onto.
  9. #208
    Apr 2013
    Preston, Garstang
    32
    96
    Re: Thread thread
    Does anyone know english axle half shaft retaining bolts? X4 on each side? I think they are unf not 100%
    also front leaf spring bolt and rear leaf spring shackle nut?
  10. #209
    Nov 2014
    Chesterfield
    27
    Re: Thread thread
    Does anyone know what size bolt goes in the hole to the right of the core plug?
  11. #210
    Mar 2007
    74
    331
    23
    Re: Thread thread
    Nudger, it's not a bolt, it's the blanking plug for the water jackets. Not sure what size it is but it is a brass hex headed plug and it's tapered so it is probably NPT.
  12. The Following User Says Thank You to Tony B. For This Useful Post:
  13. #211
    Nov 2014
    Chesterfield
    27
    Thread thread
    Cheers Tony. Does anyone know what size it should be?
  14. #212
    Apr 2013
    Preston, Garstang
    32
    96
    Re: Thread thread
    What size are the anti tramp bolts? That fit through the (front) brackets not axle
  15. #213
    Oct 2008
    whitley bay
    2,436
    89
    Re: Thread thread
    Thats listed above i posted it
    Inlet manifold bolts are 5/16unc
    Ive just been turning some
  16. #214
    Oct 2008
    whitley bay
    2,436
    89
    Re: Thread thread
    If you look through the posts above you will see it has already been listed
    Quote Originally Posted by ScottySportMk2 View Post
    1/2 unc
  17. #215
    Re: Thread thread
    does anyone know what size of bolt and thread is used to hold a compression strut cone assembly together. this is the part that clamps through the TCA and is socket head. It seems to be a very fine thread to anything else i have lying around.
    thanks
  18. #216
    TURBOSPORT SPONSOR Decade Plus User
    Turbosport Sponsor
    GP4's Avatar
    Sep 2003
    Carmarthenshire
    1,607
    Re: Thread thread
    thanks
    More often than not it's a 1/2" UNF....
  19. The Following User Says Thank You to GP4 For This Useful Post:
  20. #217
    Thread thread
    Ok so did some measuring and got 9.34mm or 0.367 inch which from googling i think is 3/8 so i reckon 3/8 unf x 1 inch does this sound correct not really an expert on imperials👍
  21. #218
    Re: Thread thread
    posty dropped some off today. 3/8 unf defo
  22. #219
    May 2009
    Dundee
    18
    Thread thread
    Can anyone help with nut size for the 4 servo mounting studs? (RS 7" servo, the nuts from a std servo are too small)
    Thanks in advance .
  23. #220
    Re: Thread thread
    5/16 unc (i believe just been looking myself) and the diff nuts should be the same just ordered some so we shall see.
  24. #221
    Pit Crew Decade Plus User THEDMAN's Avatar
    Jan 2003
    Glasgow
    819
    Re: Thread thread
    Anyone now the front bumper iron bolt thread size, so I can purchase some square nuts to replace my worn ones and weld in?
  25. #222
    I support TS Decade Plus User
    Jan 2007
    Dorset
    1,232
    168
    Re: Thread thread
    Does anyone know the thread size of the bonnet catch that screws into the inner front of the bonnet?
  26. #223
    Oct 2008
    whitley bay
    2,436
    89
    Re: Thread thread
    Anyone know the thread of the screws that hold front indicator lense on
    For a mk2 escort
  27. #224
    2,659
    268
    Re: Thread thread
    I'd hazard a guess at M5 x 0.8 but they might be M4 x 0.7
    I'm sure they'd be metric though as the Mk2 is..
  28. #225
    Oct 2008
    whitley bay
    2,436
    89
    Re: Thread thread
    No not m5 tried that
    Thinking they might be m4 but a bolt I had that was the same size and thread took a 1/4 socket ?
  29. #226
    2,659
    268
    Re: Thread thread
    1/4 would be either 6 or 7 mm wouldn't it.
  30. #227
    4,893
    Re: Thread thread
    For a mk2 escort
    The indicator lense (to the indicator) or the indicator to the bumper?
  31. #228
    Oct 2008
    whitley bay
    2,436
    89
    Re: Thread thread
    As said indicator lense
  32. #229
    4,893
    Re: Thread thread
    These screws are M4x12 (sometimes also listed as M4x14).
  33. The Following User Says Thank You to Miniliteman For This Useful Post:
  34. #230
    Oct 2008
    whitley bay
    2,436
    89
    Re: Thread thread
    thanks miniliteman
  35. #231
    Aug 2002
    Geordie Land
    2,232
    Re: Thread thread
    anyone tell me the thread on this please water outlet on pinto inlet manifold please
    MY MK1 ESCORT (Now turbo'd)
  36. #232
    Oct 2012
    Telford
    33
    137
    Re: Thread thread
    Quote Originally Posted by Stevie View Post
    According to my notes it should be 3/8" NPTF, I tapped the same adapter from eBay into a custom inlet manifold and it seemed to tighten down good, added a small dap of thread sealer for good measure.
    Mk1 Escort 1.3 XFlow Turbo - http://bytesandbolts.com/tag/mk1-escort/
  37. #233
    Apr 2003
    Liverpool
    468
    9
    Re: Thread thread
    anyone know where I can buy a complete nut and bolt
    thankyou. kit for a mk.2 rs2000.
Similar Threads
  1. Pinto Spart Plug Thread / Lambda Thread
    By Dalek in forum The Technical Section
    Last Post: 24-05-2005, 19:04
Tags for this Thread
