Page 4 of 6 FirstFirst 1 2 3 4 5 6 LastLast
Results 121 to 160 of 233
Thread: Thread thread
  1. #121
    Jun 2006
    kilkenny, ireland
    519
    Re: Thread thread
    Anyone the steering arm to RS strut bolt size?
    3/8 UNF?
  2. #122
    World Champion Decade Plus User exboyracer's Avatar
    Nov 2003
    Wirral UK
    6,740
    257
    Re: Thread thread
    Yes, I seem to remember 3/8 UNF.
    http://escort.accelerator.org
  3. #123
    Jun 2006
    kilkenny, ireland
    519
    Re: Thread thread
    Quote Originally Posted by exboyracer View Post
    Thanks!
    just to confirm, it is 3/8 UNF, i got them today, 2.5" long, 2.25" would be better if you can find them.
  4. #124
    May 2007
    nottinghamshire
    176
    Re: Thread thread
    Anybody know what thread the steering rack on a capri is, I know the mounting bolts and the rack arm lock nut its the rack its self.
    Looks about 13/16 or 21mm with a fine thread.
    sven
  5. #125
    Mar 2011
    Highley, Shrophire
    412
    Re: Thread thread
    Can anybody tell me the thread on the end of the anti roll bar (standard mk2 escort), the part that is bolted through the tca normally with a castle nut I believe? Also should the castle nut be secured with a split pin through the arb?
  6. #126
    Nov 2003
    Wirral UK
    6,740
    257
    Re: Thread thread
    Quote Originally Posted by Craig89 View Post
    I can't tell you the thread, you should be able to measure it with a steel ruler as it's pretty coarse. It should be metric.
    If you use a castle nut you need to use a split pin as you say, you can fit a nyloc instead and if you do you don't need the split pin.
  7. #127
    Pit Crew Decade Plus User merp0's Avatar
    Jun 2007
    Chester, Cheshire, United Kingdom
    1,284
    100
    Re: Thread thread
    I'm sure I had a thread gauge on one once, metric and imperial, still couldn't get my head round it
  8. #128
    Mar 2011
    Highley, Shrophire
    412
    Re: Thread thread
    I wanted to know the thread so i could use a nyloc nut as i have no holes in my arb for split pins? I thought it appeared to fine to be metric, but i might be wrong, i will measure it.
  9. #129
    World Champion Decade Plus User caprimentle's Avatar
    Nov 2009
    essex
    6,623
    338
    Re: Thread thread
    i put nylocks on mine, if no-one has found out by the end of the weekend i can tell you the thread but i need to ask my old man as his the nutty bolt man so he will know as he supplied them
  10. #130
    Mar 2011
    Highley, Shrophire
    412
    Re: Thread thread
    I measured the thread tonight and it appears to be 16mm x 1.5mm, so M16 fine? Does this sound about right?
  11. #131
    Nov 2009
    essex
    6,623
    338
    Re: Thread thread
    i forgot to text the oldman i'll text him tomorrow if i think of it, that does sound about right though to what i can remember.
  12. #132
    May 2007
    nottinghamshire
    176
    Re: Thread thread
    End of roll bar =5/8 unf
  13. #133
    Nov 2009
    essex
    6,623
    338
    Re: Thread thread
    any one know the length, pitch, and tensile strength of the larger 17mm head bolts that holds the crown wheel on an l.s.d in an atlas?
  14. #134
    Nov 2009
    essex
    6,623
    338
    Re: Thread thread
    Quote Originally Posted by caprimentle View Post
    anyone
  15. #135
    2,661
    268
    Re: Thread thread
    anyone
    Still not sure what size they are but Burton's do them, they're on fleabay.
    http://www.ebay.co.uk/itm/Atlas-Axle...item231066fc72
  16. #136
    Nov 2009
    essex
    6,623
    338
    Re: Thread thread
    doesn't mention whether they're the bigger head or not, non l.s.d's had a 15mm head while l.s.d's had a 17mm head, i've got the 15mm but not the 17 mm, just wondered what strength they needed to be
  17. #137
    Nov 2003
    Wirral UK
    6,740
    257
    Re: Thread thread
    I would imagine they would be the same for a non-LSD diff, they can't be under any different stresses
  18. #138
    Nov 2009
    essex
    6,623
    338
    Re: Thread thread
    it says 100 on the head which i assume would be a 10.0, i'm gonna measure the thread so i can find out what thread they are, also i reckon lsd bolts are longer as i measured today an open diff is 10 mm thick but l.s.d is 12 mm, so i'm loosing 2 mm of the bolt thread, so with the open diff bolts threw the lsd only about 2-3 mm of thread goes into the crownwheel where as it would be 4-5 mm with the open diff.
    i went to burtons today too and they only sell the 15 mm head bolts, not the 17 mm ones.
  19. #139
    Mar 2011
    Highley, Shrophire
    412
    Re: Thread thread
    Quote Originally Posted by sven View Post
    I can confirm that this is correct, I have now fitted 5/8 unf nylocs to my arb
  20. #140
    2,661
    268
    Re: Thread thread
    Im just thinking, aloud (dickhead) lol; isnt there a general engineering rule that says a bolt should go into a thread the equivalent of at least its own diameter?
    So an M8 bolt would go into a thread at least 8mm, M10-10mm an so on?
    Or am I mislead in this?
  21. #141
    Nov 2009
    essex
    6,623
    338
    Re: Thread thread
    either way i wernt happy with how far in the thread it went so i bought some of these http://www.gartrac.com/shop/atlas-ax...heel-bolt.html expensive i know for a set of 8 but if it saves the axle destroying itself i aint gonna moan
  22. #142
    Re: Thread thread
    Anyone know the thread of the balance bar on a pedal box on the Mk1 (if that makes a difference) need one for a locknut to stop the adjuster coming undone.
  23. #143
    Jun 2007
    South West
    1,985
    87
    Re: Thread thread
    Mk2 Escort steering column top nut anyone? I've read M16 with a 2mm pitch elsewhere but if someone could corroborate that I'd appreciate it.
  24. #144
    Racer Decade Plus User mexicotait's Avatar
    Oct 2008
    whitley bay
    2,436
    89
    Re: Thread thread
    Green rs track rod end thread of the part that goes through the steering arm ?
    Hexham and District Motorclub
  25. #145
    Mechanic Bigfish's Avatar
    Dec 2009
    Beds
    891
    Re: Thread thread
    evening
    does anyone know what the correct bolt size for
    MK1 escort
    steering colunm to bulkhead
    steering colunm to dash
    thanks
    1974 MK1 Escort - Work in Progress
  26. #146
    Spanner Monkey Phil01825's Avatar
    Dec 2005
    East Sussex
    335
    Re: Thread thread
    I'm looking for the thread size for the bolts fixing the handbrake to the tunnel. Also looking for the threadsize of the small bolts that fix the ARB mounting bracket to the front lower crossmember
  27. #147
    Dave's Avatar
    Oct 2003
    Cheshire
    19,588
    141
    Re: Thread thread
    last 3 questions have already been answered in this thread if you look.
  28. #148
    Dec 2005
    East Sussex
    335
    Re: Thread thread
    I found a question about the ARB front bolt but no answer and I can't see anything about the handbrake lever bolts.
  29. #149
    Dave's Avatar
    Oct 2003
    Cheshire
    19,588
    141
    Re: Thread thread
    If a 7/16" spanner fits it, it is 1/4" bolt
    if a 1/2" spanner fits it, it is 5/16" bolt
    If 9/16" spanner fits it, it is 3/8" bolt
    If 5/8" spanner fits it, it is 7/16" bolt
    If 3/4 spanner fits it, it is 1/2" bolt
    If there are lots of close together threads it is UNF, (F stands for fine)
    If there are not so many threads it is UNC (C stands for coarse)
    A 13mm spanner is pretty much the same as 1/2"
    A 16mm spanner is pretty much the same as 5/8"
    A 19mm spanner is pretty much the same as 3/4"
    Anything else and you are using the wrong spanner and deserve to have your nuts rounded off (IMO )
    So, bolts that hold the handbrake on are going to be undone with either a 7/16" or 1/2" spanner (can't remember which) so from that you can work out the size of them.
    By looking to see if the threads are fine or coarse you can figure out if they are UNF or UNC.
    Without looking I would guess they are 5/16" UNC.
    ARB is probably going to be 1/4" UNF, but that is just a guess. Using the above info you can figure it out easy enough for yourself if you look.
  30. The Following User Says Thank You to Dave For This Useful Post:
  31. #150
    Nov 2003
    Wirral UK
    6,740
    257
    Re: Thread thread
    From memory the handbrake securing bolts are a 1/2" head
  32. #151
    Dec 2005
    East Sussex
    335
    Re: Thread thread
    That's the problem starting with a bare shell, there weren't many bolts which is why I'm buying new ones. None of the bucket of bolts I picked up with the shell fit these captive nuts and the few others I've got are mainly cap head bolts hence why I was asking for some sizes.
  33. #152
    Dave's Avatar
    Oct 2003
    Cheshire
    19,588
    141
    Re: Thread thread
    Buy a few of the above sizes and work it out. It is easy, honest.
  34. #153
    Pit Crew gorilla1q's Avatar
    May 2009
    Cheshire
    1,345
    Re: Thread thread
    Quote Originally Posted by Dave View Post
    A top tip Dave what sort of lengths would be best in the sizes???? Think I may go to websters or Leighton fastners and buy a ruck of bolts in them sizes for my rebuild when it happens
    When I grow up I will have a MK1 Escort
    I must be all growed up now then and paying for it!
  35. #154
    Dec 2005
    East Sussex
    335
    Re: Thread thread
    Cheers Dave, I found a couple of more old bolts in the shed. They are 5/16 (1/2" Spanner) and fit the handbrake and front Anti Roll Bar mount holes. I'm not sure it they're UNF or UNC but will be getting a few new ones of various types for bolting up so will be able to tell then.
  36. #155
    Dec 2005
    East Sussex
    335
    Re: Thread thread
    Anyone know the thread size for the steering wheel nut on a corsa b electric power steering column??
  37. #156
    Dec 2005
    East Sussex
    335
    Re: Thread thread
    Quote Originally Posted by Phil01825 View Post
    They were 5/16 unc
  38. #157
    I support TS Decade Plus User
    DENZIL's Avatar
    Apr 2007
    bristol
    1,850
    91
    Pinto temp sender can anyone tell me the corrct thread cheers
    lightening gone but never forgotton
  39. #158
    Nov 2003
    Wirral UK
    6,740
    257
    Re: Thread thread
    1/8 npt IIRC
  40. #159
    Pit Crew Decade Plus User MK1_Oz's Avatar
    Nov 2008
    Adelaide, Australia
    1,331
    96
    Re: Thread thread
    I looked but could not see the bolt size for the gearbox crossmember into the bottom of a Type 9 box??? Also, Mk1 Escort gearbox crossmember into chassis bolts?? Cheers
    1970 Mk1 Escort Tarmac Rally Car
  41. #160
    Nov 2003
    Wirral UK
    6,740
    257
    Re: Thread thread
    IIRC the gearbox to crossmember is M12 fine but I wouldn't want to bet my life on that...
    I reckon the crossmember to body bolts are 5/16 unf
  42. The Following User Says Thank You to exboyracer For This Useful Post:
  1. Pinto Spart Plug Thread / Lambda Thread
    By Dalek in forum The Technical Section
    Last Post: 24-05-2005, 19:04
Tags for this Thread
