Results 1 to 17 of 17
Thread: ST170 ECU/Injector/carb setup
    Jul 2016
    Ireland
    187
    Looking for advice for ECU/Injector/carb setup for an ST 170 Silvertop engine in an escort Mk1.
    The two main contenders at the moment are
    Firstly the fairly expensive - Ford Zetec 1.8/2.0L (silvertop) Throttle Body Kit
    LINK - Omex
    OR the cheaper DanST Ford Zetec 1.8/2.0 Bike Throttle Bodies Kit GSXR 42mm *FAST ROAD PACK*
    LINK - DanST
    coupled with NODIZ Pro
    LINK - NODIZ VVT ECU
    To run the engine VVT
    Any thoughts or other suggestions????
    9,204
    Contact graham on here for a jenvey / emerald quote ?
  3. The Following User Says Thank You to alladdin For This Useful Post:
    Re: ST170 ECU/Injector/carb setup
    st170 isnt a silver top engine, its a black top badged as a duratec.
    re vvt, you cant control it with an ecu which simply switches it on a certain rpm, for it to work properly the ecu has to have a proper VVT map.
    from me an emerald K6 with part loom and a couple of sensors is £775 all in delivered.
    a k6 with jenvey ckfd03 throttle body kit and linkage ( but no loom) is £1680 delivered.
    you can save some money on the above by not having the full body kit from jenvey but instead buying a dcoe manifold from burtons/retro ford etc and my special offer throttle body kit.
    if all you want is the K6 then its £660 delivered.
    what ever way to go, doing it right isnt cheap
  5. The Following User Says Thank You to Graham For This Useful Post:
  6. #4
    3,241
    The Nodiz VVT controller is mapable and 3D apparently.
    Regarding the TB's, its just down to what you want to see, as end of day they both will achieve the same goals.
    45mm Jenvey's may flow a tad more air over the 42mm GSXR TB's and so may work 'better' with the fully controlled VVT?
  7. The Following User Says Thank You to katana For This Useful Post:
  8. #5
    Jul 2016
    Ireland
    187
    Thanks - I'm really interested - is this it -
    LINK - Jenvey ckfd03
    LINK - Emerald K6
    Could you supply a complete kit with all the sensors,air filters, wiring loom etc. needed.
    Basically I have a friend who's helping me install an ST engine into a MK1 Escort - he's sold on the Omex system but hasn't really looked at any of the other systems available - I'm not convinced Omex is the way to go - in truth - I'm not really up to speed on the ST engine but I'm struggling to see the point of installing an engine with VVT and then having no control over it (not that I actually know what the advantages of VVT are -lol??)
    Really, any help gratefully received.
  9. #6
    9,204
    You either need to fully control it or invest in cams etc. Or your wasting power.
    And You still need an ecu.
  10. The Following User Says Thank You to alladdin For This Useful Post:
  11. #7
    3,241
    VVT Operation - think of it like cams control airflow and the efficiency of filling the cylinder determines torque output so normally there will be peaks and troughs in a torque curve if timing is fixed, but if you have the facility to move the cam around then the airflow and hence the torque can be improved in the troughs whilst retaining the peaks so smoothing the curve - thats the principle behind VVT.
  12. The Following User Says Thank You to katana For This Useful Post:
  13. #8
    Jan 2008
    Milton Keynes
    137
    Quote Originally Posted by Perry Oaks View Post
    LINK - Emerald K6
    I'll be hopefully putting my order in with Graham for that lot tomorrow, air temp, water temp, tps included. As said you'll need a loom and injectors, but pretty much ready to go, I've built my own loom from the original focus one and have the original injectors to use also
  14. The Following User Says Thank You to escos For This Useful Post:
  15. #9
    Jul 2016
    Ireland
    187
    Thanks Guys - so its well worth getting an ECU that controls VVT.
  16. #10
    a lot depends on how you control the vvt on some engines it can succeessfully be done by connecting it to a shift light, ie reach a certain rpm and simply switch it on, not so with the st170, it needs to be switched on in the midrange and off again at higher revs, so not something possible with a system which does a simple rpm switch
  17. #11
    Jun 2003
    Teesside
    2,406
    By not using the vvt and simply locking the cam at optimum power timing you don't gain or loose the peak power you can get.
    But at lower revs, approximately 2500rpm and below if the vvt is used to change the timing you gain a few extra horsepower and just over 20ft/lbs torque. So if your not after the maximum engine power spread you don't need the vvt.
    Also if you go for longer duration cams you will most likely need to go for fixed cams or get bigger pockets machined in the pistons.
  18. #12
    not sure on above, emerald are regularly seeing 200 bhp on internally standard engines using full vvt control, just throttle bodies and decent exhaust add a flowed head and 210 bhp is on the cards.
    both figures quite a bit more than i see to recall these engines giving with out full vvt control
  19. #13
    9,204
    I supposed if u know the exact advance for max power and lock it at that point then max power would be the same but it's likely to loose a lot everywhere else
  20. #14
    Jul 2016
    Ireland
    187
    Graham - would you be able to supply a full kit - all sensors - complete loom - injectors - air filter etc. A 'plug and play' system with everything I need?
  21. #15
    maybe, i can and do supply most of it, but im not sure about being able to do a plug and play loom.
    i will see if i can get a loom made, if theres enough interest i might even commission a batch of them
  22. The Following User Says Thank You to Graham For This Useful Post:
  23. #16
    Jul 2016
    Ireland
    187
    That's brilliant - I appreciate that - thanks
  24. #17
    Jul 2011
    London
    Hi perry did you ever vet engine up and running what route did u go down
