is there only 1 vvt controller on the market or are there others
Some ecu have the function built in
currently got a megajolt fitted and now looking for a controller to work with it
cheers
Motorsport electronics controller is fully independent so can use your maga jolt
Only one standalone vvt controller I am aware of but various ecus have various levels of vvt control available.
better off locking the cam and deleting the vvt matey
Only better off financially tho
personally, unless youre upgrading your cams and induction, I wouldn't bother with locking cam off. if you get the vvt working right, youll still get the same power as locking off, but youll also have more grunt for a longer band. a few ecus that give you full vvt control, well worth it imo.
I only know of the one, Motorsport electronics its £200 ish I think. well worth it to get the VVT otherwise I don't think its much different to a standered black top! I'm currently putting the ST170 into my car but using the Emerald ECU.
