Page 7 of 8 FirstFirst 1 2 3 4 5 6 7 8 LastLast
Results 241 to 280 of 313
Thread: Removing Choke Butterflies from 32/36
  1. #241
    25,110
    Re: Removing Choke Butterflies from 32/36
    sorry thats too small i cant read it
  2. #242
    May 2010
    london
    1,139
    hope this is better..
    Have to use stnd exhauste manifold and down pipe. Cam modify after that.
    Have to use 32/36
    have to use stnd to pinto range..
    Cheers madragon
  3. #243
    25,110
    so you have to use the 32/36 and a std inlet manifold, which means the 40 DFAV isnt any use anyway unless you want to cheat, but not only would such a cheat be very easy to spot
    it means if you do win anything you wont really be winning.
    the only real option you have is to raise the compression, with relatively restricted breathing as long as the engines set up right and doesnt detonate you can probably push the compression beyond the 10.5:1 CR normally considered safe maximum on cast pistons to 10.75, if you engines about 10:1 now then 0.75 more on the CR will make a noticable difference
  4. #244
    Nov 2009
    essex
    6,623
    338
    sorry to change subject again but do you reckon the 40dfav is worth a try or do you reckon the 38 would be better for everyday then?????,
    and if i was you madragon, i would just port the hell out of everything as much as i can and raise compression like graham has said, i belive you can also 5 angle the valves, but personally i'd look elsewhere for half a second like tyres or suspension, not much more could be done could be done to the engine to help with times that much i would think.
  5. #245
    May 2010
    london
    1,139
    Hi. Compression is 10.5 -1 my spelling error.
    I am not allowed to port anything. Thats why i use the injection head it flows slightly better.
    On the carb idea if i raised the carb up by extending the manifold(tig and ally) then spaced with standard spacer will it help(more flow more fuel?)
    i can modify the spindles and i could change the butterflies for thinner ones i would have to counter bore the holes for the retaining screws as i have to use stnd ones. Lastly is it worth making a air filter that works like a trumpet( poss bending the rules )
    cars set up ok positive camber +negative camber ofset positve caster 3.9 locked diff
    cheers madragon
  6. #246
    Dec 2004
    Ireland
    1,781
    31
    Something you could do but I am not sure if it bending the rules is seal up a standard airbox and run the air inlet from a point of high pressure on the car. One location of the would be the the base of the windscreen or somewhere on the front of the car. THis would act somwhat like a turbo forcing air into the engine and would also help by providing cold air rather than the hot under bonnet air.
    What modifications can you make to the exhaust manifold and system as there could be a lot to gain by modifying that.
    Regards
    Tom
  7. #247
    25,110
    [QUOTE]
    /QUOTE]
    but all of thats cheating!!!!!!!!!!!!
    [QUOTE]Hi. Compression is 10.5 -1 my spelling error.
    I am not allowed to port anything. Thats why i use the injection head it flows slightly better./QUOTE]
    then go a bit more on the compression, go to 10.75,
    which is all going way off topic on this thread cos none of the carb mods in this thread can be done within the rules
  8. #248
    Nov 2009
    essex
    6,623
    338
    well sticking to the thread, what carb do i use so i know what carb to modify so i can get some rolling road results on this thread. do i use my 40dfav or do i buy a 38dgas.
  9. #249
    25,110
    ultimately power is the name of the game here so modify the 40 DFAV, but make sure you also port the manifold to make the most of the carb
  10. #250
    May 2010
    london
    1,139
    thanks .. just looking for a mod to the carb that isnt cheating... back to the drawing board
  11. #251
    Nov 2009
    essex
    6,623
    338
    llike i say i'll definately port the manifold but will it become undrivable on the road and have catastrophic affects on the fuel gage compaired to the 38 dgas, coz the car will still be everyday, and i dont want fuel economy and drivability to suffer so much more compaired to the 38 just for the sake of an extra 5-10bhp or so. i know nothing of these 40dfav's or mechanical power valves so i do appologise if these questions are irritating, its my last one i swear then i'll leave you alone till the next problem
  12. #252
    25,110
    i've never used a 40 DFAV on a pinto, but have used it on a 2.0 fiat twin cam engine, it worked very well
    unless your engines heavily modified i doubt the DFAV would make 10bhp more than the DGAS
  13. #253
    Sep 2003
    Barbados
    1,284
    19
    Graham,
    The engine is a 1690xflow with a big valve ported head, Kent 234 cam, H&H modified curve dizzy with vac advance, electronic igntion, 105Speed 'Mass' style exhaust manifold and 2" system, ported & JB welded inlet manifold.
    The carb has the butterfly spindles thinned down and the screws countersunk, it also has modified auxy venturies with one leg thinned right down and the leading edge of the venturi sharpened Both carbs were tested with the carb 'hat' fitted..
    Both me and the RR operator were surprised as we both expected more from the modded carb
    would a single sidedraft 40mm on a lynx manifold be better or worse overall? i hear the lynx single manifolds dont flow to well.
    1973 mk1 escort
    1982 Toyota corolla ke70
    1988 mk4 escort
  14. #254
    Sep 2008
    North Shropshire
    97
    I finally got around to putting the modified 38 DGAS on the bench today
    The picture shows the actual depression the reading was taken is on the main screen and the little box in the corner is the equivalent flow at 25" - so I could take a comparison to the flows in Vizards SOHC book
    The head is coming off the SOHC in the Ginetta in the next week or so for some head mods so I will drop the DGAV on there as well to test it.
  15. #255
    Sep 2008
    North Shropshire
    97
    Oooooppps - serves me right for being so lazy and optimistic - I put the DGAV on and it flowed 302CFM - Not exactly right.... So I checked the calibration on the bench and it was way out - then checked the logs and the last time I used i was 6 months back!
    So I did what I should have done and calibrated the bench and then ran the tests
    32/36 DGAV - 260CFM - bit shy of what Vizard obtained but there or there abouts
    38 DGAS - 295CFM
    A flow difference of just over 13%
    The only difference between the two carbs are the butterfly diameters which is why the difference is not that marked It would be interesting to find the figures for the stock carbs
    The difference between the start and the finish of Vizards mods on the DGAV was just shy of 17% for a large choke size increase so an additional 13% is very good for the DGAS
    Making a comparison between the stock DGAV at 227 and a fully modded DGAS at 295 is a 30% increase in flow this also ties in with the flow figures on the 40DFI at 330 CFM
  16. #256
    Nov 2003
    Wirral UK
    6,740
    257
    I've got a highly modded 32/36DGAV here, I'd be very interested to see what it flows. I'm not all that far away from you so maybe I could pop over one day?
    http://escort.accelerator.org
  17. #257
    Sep 2008
    North Shropshire
    97
    You would be more than welcome drop me a PM
  18. #258
    Nov 2003
    Wirral UK
    6,740
    257
    Will do
  19. #259
    Mechanic Turbosport Subscriber ebenech's Avatar
    May 2010
    Montevideo, Uruguay
    495
    61
    Hi Graham. I'm quite delayed with my question, and also please excuse me for my poor knowledge of the english language. So, my question is: There is an improvement by adding spacers under de carburettor, but "mainly because the carburettor appear bigger". What do you mean by saying "the carburtettor appear bigger" ? Is that related with the carb improvement ? Sorry for my question, and look forward to you kind answer. Best regards.
    Eduardo
    adding spacers does give an improvement, some times the improvement comes because it give the air more time to turn the corner after it leaves the carb,
    but mainly it comes because it makes the carb appear bigger as far as the engine is concerned, although it doesnt seem like it, an engine on a single carb is still sucking air in in pulses we can use this to create a slight supercharging effect by having a store of air under the carb ready for when the next valve opens, even when modified the carb cannot supply all the air the engine wants which leaves a greater vacuum in the manifold inbetween the engines induction strokes the vacuum will continue to fill the manifold with air, when the next induction stroke occurs the engine will consume the additional air stored in the manifold as well as what it can draw through the carb hense the engine behaves as if it has a slightly bigger carb than it really has.
    i remember one engine when vizard was really going for it on a single carb engine he also made the manifold branches longer by cutting the manifold and welding tubes into the port runners to make them longer, again it adds to the manifold volume and with teh runners may of even imparted a bit of ram tuning
    as for porting the manifold, this should give you the right idea.
    if your really going for it you would build up the base of the manifold in the middle of the plenum to mirror the new shape of the runners this would reduce charge robbing from one cylinder to another
  20. #260
    May 2010
    Montevideo, Uruguay
    495
    61
    Duck Re: Removing Choke Butterflies from 32/36
    HI Graham,
    Sorry for my delayed question and for my poor understanding of the english language. My question is: what do you mean when you say improvements by adding spacers. . . . . mainly "the carb appers bigger" What that it means, I get a bigger cargurettor thus better performance ? Sorry for my question, and look forward to your kind reply.
    Best regards,
    Eduardo
    but [COLOR="red"]"mainly it comes because it makes the carb appear bigger as far as the engine is concerned," [/COLOR[ although it doesnt seem like it, an engine on a single carb is still sucking air in in pulses we can use this to create a slight supercharging effect by having a store of air under the carb ready for when the next valve opens, even when modified the carb cannot supply all the air the engine wants which leaves a greater vacuum in the manifold inbetween the engines induction strokes the vacuum will continue to fill the manifold with air, when the next induction stroke occurs the engine will consume the additional air stored in the manifold as well as what it can draw through the carb hense the engine behaves as if it has a slightly bigger carb than it really has.
  21. #261
    May 2010
    Montevideo, Uruguay
    495
    61
    Hi, this is a message to Graham Bahr,
    Graham, I have a 1700 x-flow with a 285 piper cam kit and stage 2, (big valves), Vulcain Eng. head in my MK II. My carb is a 32/36 and since I put it to the engine it has the choke butterflies removed. Now, I have a question. In one of your posts you say add spacers to the carb for improvement. I'm doing this, and I understand I will give more speed to the mixture, but what I don't get is the meaning of "mainly the carb appears bigger". I'm sorry for my poor understanding of the english language, but please be kind enough and clarify to me this point.
    All my best, and look forward to your kind reply,
    Eduardo
  22. #262
    25,110
    if you have a carb which is restricting the engines powerout often adding some spacers under the carb will give a little more power
  23. The Following User Says Thank You to Graham For This Useful Post:
  24. #263
    Sep 2008
    North Shropshire
    97
    I carried out some further flow tests on the 32/36 today to compare the flows through the two chokes
    Figures are at 25" and are comparative figures
    32mm choke with 30mm venturi - 139 CFM
    36mm choke with 30mm venturi - 158 CFM
    The 36mm choke flows 15% more air than the 32mm with the same venturi.
    I am assuming that this is because the shaft and butterfly create a proportionately larger restriction to flow in the 32mm diam choke than in the 36mm choke - I would have tested this but as I had screwed and glued the shafts in I did not want to disturb them.
    I did a flow comparison between narrowed and standard AUX venturi and the difference in the 32 and 36mm chokes was no more than 0.5CFM - so dont waste your time on that mod.
    Andrew
  25. #264
    25,110
    indded i came to teh same conclusion it didnt achive anything
  26. #265
    May 2010
    Montevideo, Uruguay
    495
    61
    Hi mates, I have this situation in this moment. My "big bore" was doing almost 100% OK with this configuration: Airs 170 - 160, Mains 150 - 155, idle 55 - 55. Now, I add one standard spacer to my 32/36 DGAV and things screwed up. Again clogged spark plugs very quickly. So I started changes in the mains. first 145 - 150, problem still there but not that quickly. second 145 - 145, that looks quite allright, but I'm scared of getting lean when I'm at WOT, since std mains for my DGAV are 140 - 140. So I came to think what happens if go all the way round and mantain my original mains at 150 - 155, but increase my Airs to 180 - 170. My thinking is that if I have more velocity by adding a spacer, well I'll rather need more air than less petrol in the mixture. These thinking make any sense at all ?
    Please let me have your coments, since I'm in the process of "test and error", and I don't want holes in my pistons when I'm at WOT.
    Thanks in advance for you fine cooperation.
    Eduardo
  27. #266
    May 2010
    Montevideo, Uruguay
    495
    61
    Hi, when i said added a spacer, means that now I have 2 spacers. Oh well.
  28. #267
    Nov 2009
    essex
    6,623
    338
    what is WOT?
  29. #268
    Dec 2004
    Ireland
    1,781
    31
    WOT (Wide Open Throttle) Pedal to the metal, foot on the floor, etc etc
  30. #269
    May 2010
    Montevideo, Uruguay
    495
    61
    what is WOT?
    What your Capri is doing seems to be WOT
  31. #270
    May 2010
    Montevideo, Uruguay
    495
    61
    what is WOT?
    What you Capri is doing seems to be WOT
  32. #271
    May 2010
    Montevideo, Uruguay
    495
    61
    Quote Originally Posted by ebenech View Post
    Eduardo
    Answers please, need your help,
    Nov 2009
    essex
    6,623
    338
    aahhh o.k nice, been wondering what that has ment for a while lol
    cant help you with your problem unfortunately but it does seem very odd, what your saying does makes sence to an extent but i have no idea to wether it will work, your best of setting it all back to normall untill someone here with more knowledge than us comes up with a logical explanation for it all
  34. #273
    25,110
    Eduardo
    something else has happened/changhed/broken because adding 1 spacer cannot effect the mixture so dramatically
  35. #274
    May 2010
    Montevideo, Uruguay
    495
    61
    Thanks Graham for your advise, I'm going to check if something had happened/changed/broken on my carb. Maybe the problem is there.
    Cheers,
    Eduardo
  36. #275
    May 2010
    Montevideo, Uruguay
    495
    61
    Hi "WOT" Caprimentle, It's good that you now are awared of what WOT is, since you do it all the time. Also thank you for your advise about my jetting problem, already Graham gave me a clue to look in some other problems that might be happening to my carb.
    Cheers,
    Eduardo.
    PS And don't forget, always WOT
  37. #276
    25,110
    maybe you carb was leaking in air around its base and adding the second spacer helped seal the air leak????????????
  38. #277
    Nov 2009
    essex
    6,623
    338
    i would think the idle would of been very rough for him though, and when my carb was letting in air it was making a horrible whistle, but like you say one spacer should not make such a difference.
  39. #278
    May 2010
    Montevideo, Uruguay
    495
    61
    Yeah Graham, I'm working on that. After your previous advise, I took the carb out, checking everything, and I'll check
    for air leeks on the spacers. Once I install it again and see what happens, I'll post again about this matter. Many thanks,
    Cheerio,
    Eduardo
  40. #279
    May 2010
    Montevideo, Uruguay
    495
    61
    Hi Caprimentle, Many thanks for your reply. I'm working on my carb to see what happens.
    Cheers,
    Eduardo
  41. #280
    Ireland
    3,579
    173
    The reason spacers under the carb work better by lifting the carb higher is because this gives the fuel a much better chance of turning the corner into the port runners and still staying in suspension with the air instead of dropping out of the air stream, air can turn a lot tighter than fuel can, fuel wants to go straight onwards instead of turning round sharp bends, fuel is a lot heavier than air
Similar Threads
  1. 32/36 DGAV with k&n
    By DaveWRC in forum General items for sale
    Last Post: 12-11-2005, 01:43
  2. Weber 32/36 DGAV
    By ludsonline in forum The Technical Section
    Last Post: 30-05-2005, 20:14
  3. 32/36 Info
    By SidewaysMk1 in forum The Technical Section
    Last Post: 18-07-2004, 15:22
  4. 32/36 DGV
    By Ratters in forum The Technical Section
    Last Post: 24-04-2004, 12:27
