Results 1 to 5 of 5
Thread: Cam affects/which to go for
    Oct 2015
    north wales
    31
    Hi.
    Currently have a fully lightened and balanced stroker bmw m44 engine (318 1.9 16v bored to 2100cc) with block capable of 8000rpm.
    Stock head other than being ported.
    Cams are listed as 244 with10.2mm of lift.
    Car is very tame. It idles like a standard car and drives like a standard car with more power.
    Im considering a set of catcams as ive found a cheap set.
    Which are 283 / 284 10.75 lift.
    Car is soley used for competition and is still on standard inlet.
    Currently at around 169bhp and 161ftlbs i think
    Im thinking of fitting above cams with a bored throttle body. What affect am i likely to get. Will it still be as driveable? More power? Torque?
    Mar 2012
    Shropshire
    407
    Re: Cam affects/which to go for
    Have a look on the cat cams site and it should give you a guide to the rpm range they make power in
    lumpy cams and std plenum will idle and run badly at low speed.
    Oct 2015
    north wales
    31
    Theduck thanks although there is no info about this on catcams website other than the spec ive listed and couple other sizing specs.
    Would you say that these are to lunpy Graham?
    Thanks for the reply!
    Sion
    look at the lift at tdc figures, that says far more than timing
